Missing hardware in strut tower after lowering springs install
FoxtrotLima5
Drew
SF Bay Area
2023 FL5
Had H&R lowering Springs installed by a local performance shop last week , today I noticed missing hardware from both strut towers, can yall advise if it normal or indeed a problem ?
Thank !
11th Gen Honda Civic Missing hardware in strut tower after lowering springs install IMG_0130
11th Gen Honda Civic Missing hardware in strut tower after lowering springs install IMG_0129
Thank !
So its not a problem if you go get it aligned and they shift the struts to help with camber. But by taking out those pins if they just tightened them randomly they will be out of position slightly. So alignment and adjustment should be a priority.
FoxtrotLima5
FoxtrotLima5
Drew
SF Bay Area
2023 FL5
Thanks Bud. Alignment seems spot on, he did recommend checking the alignment again once the lowering springs settles
Don’t just go by feel, let the springs settle and go make sure everything is in spec. It will give you peace of mind.
s2kdriver80
You can cover it up with the OEM hole seal (or any heavy duty sticker) to minimize the eyesore, wipe down with rubbing alcohol and apply. Don't think the FL5 has a triangular bracket that gets in the way like it does on the FK8 strut tower, so should have easy access.
02SilverSiHB
Annapolis, MD
2023 FL5
is it just me, or does that look like they wanted to go positive in camber? Or maybe I'm looking at it wrong
