PRL Motorsports 2016+ 1.5T Civic Stock Location Charge Pipe Hose Upgrade Kit
Status
Not open for further replies.
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
11th Gen Honda Civic PRL Motorsports 2016+ 1.5T Civic Stock Location Charge Pipe Hose Upgrade Kit Charge%20Pipe%20Black%20Full%20kit_zps815h50hi
11th Gen Honda Civic PRL Motorsports 2016+ 1.5T Civic Stock Location Charge Pipe Hose Upgrade Kit Charge%20pipe%2090%20three%20colors_zpshapmkue6
11th Gen Honda Civic PRL Motorsports 2016+ 1.5T Civic Stock Location Charge Pipe Hose Upgrade Kit 3%20colors%20charge%20pipe%20long_zpsk7xa2ykx
11th Gen Honda Civic PRL Motorsports 2016+ 1.5T Civic Stock Location Charge Pipe Hose Upgrade Kit 3%20colors%20ribbed%20charge%20pipe_zpsx8jmj6y
Replace your stock, boring, rubber charge pipe hoses with our bright and exciting 4-ply silicone hoses. Not only does this kit improve engine bay aesthetics, our 4-ply reinforced couplers increase strength and durability by better withstanding the high heat of the engine bay.
Our stock location charge pipe hose upgrade kit for the 1.5L Turbo Honda Civic fits both Si and Non-Si models.
Kit Includes:
  • (1) Throttle Body Inlet Hose
  • (1) Hot Side Charge Pipe Hose
  • (1) Cold Side Charge Pipe Hose
  • Stainless Steel Compression Rings
  • Stainless Steel Breeze Liner Clamps
Hoses available in our signature black/blue PRL Motorsports design, red and neon green!
http://prlmotorsports.com/201615tcivicstocklocationchargepipehoseupgradekit.aspx#.WbMP4rJ96Uk
SpaceJunkie
Nigel
Singapore
Honda Civic 1.5T 2016
I’m on PRL FMIC, using stock charge pipes. Any issue if i intend to install this hoses for aesthetic purposes?
SpaceJunkie
Nigel
Singapore
These are not compatible with the upgraded intercooler!
I thought it’s the OEM hose replacement, and upgraded intercooler is just connected to the OEM charge pipes?
Incompatible because of technical issues or fitting issue?
Status
