PRL P-07F Forged Wheel Set
Status
Not open for further replies.
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
We have been working on a special project. Many of you knew these were coming, & we are happy to release the first ever set of PRL wheels! Our goal is to introduce a product that represents our passion and dedication to the Honda aftermarket, but with a unique touch from PRL. This project also showcases our commitment to quality manufacturing and performance engineering. We're excited to unveil the result!
We are thrilled to introduce the new PRL P-07F Wheel to our expanding product line. This bespoke, forged wheel set pays tribute to the iconic EK9 Type R wheels of the late '90s, yet, it features modern specifications to accommodate the 10th and 11th generation Civic Type R's from 2016 to the present.
Currently available in Washi Grey, this 7-spoke, 5x120 design is simple and perfectly complements the design language of these modern chassis. The P-07F is exclusively available as 18x10.0 ET +47mm, which we've found to be the ideal flush fitment on the Civic Type R. The wheel is designed to accommodate a range of tire sizes, from the recommended 275/35/18 size up to a highly aggressive Hoosier A7 295/30/18 track tire. This allows you to choose a tire size that best suits your personal driving style.
11th Gen Honda Civic PRL P-07F Forged Wheel Set 1716908379668-iq
11th Gen Honda Civic PRL P-07F Forged Wheel Set 1716908416007-rv
11th Gen Honda Civic PRL P-07F Forged Wheel Set 1716908464452-dx
11th Gen Honda Civic PRL P-07F Forged Wheel Set 1716908513470-lz
Quick Specs:
  • 5x120 Bolt Pattern
  • 64.1 Hub Centric Bore
  • 23.5lbs per wheel
  • Fitment / Offset 18x10.0 ET 47mm - Ideal fitment on FK8 and FL5 platforms
  • 60º Conical Lug Seat - Not compatible with OEM lugnuts
  • Made from a proprietary blend of high silica 6061 Forged Aluminum for increased tensile strength
  • PRL machined billet aluminum, Washi Gray painted center caps included
  • Knurled bead seat
  • Optimized strength and weight by FEA analysis
  • Sold as a set of 4, not sold individually
LINK: https://prlmotorsports.com/products/prl-p-07f-forged-wheels
11th Gen Honda Civic PRL P-07F Forged Wheel Set 1716908987822-qt
pharmerlee
lee
cali
civic type R FL5
what's PRL's recommended suspension and alignment setup for these wheels? what tires where test fitted to these wheels? I understand that each tire brand differs. will 285/35 tires fit without rubbing or needing fender work?
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
The goal was to create a wheel that will fit properly at all different ride heights. 285 will fit just right! We had no rub on the 295s in the photos above. Alignment & tire selection is key & will depend on what exactly you are looking for. We test fit with Azenis RT660's, as it is one of the most popular tire choices. I do not have our last alignment sheet on me, but we went with factory specs for the project. The yellow FL5 above is running a 275 & is on bags. We made a wheel to cater to everyone from stance to track without having to do crazy alignment settings. Very versatile!
pharmerlee
lee
cali
civic type R FL5
thanks I'm looking forward to these wheels. I plan on lowering on eibach prokit with 285/35. I want a beefier tire look. just hope it won't rub or require fender work.
pharmerlee
lee
cali
civic type R FL5
will these wheels clear aftermarket BBK? which kits would you recommend?
Alexx
Alex
2025 Civic Type R, 2022 BMW M4
Does 265x35x18 fit on them and do OEM center caps fit?
Sporky McGeuschky
Sporky
Central Texas
@PRL Motorsports
Great looking job!
Hi. I hope y'all are successful with these wheels.
I am not a fan of this particular spoke pattern (7 spoke). Personal preference.
On the other hand, I LOVE the fact that these are deep dished! Definitely not enough dished forged wheels out there for the FL5.
Keep up the good work!
realtorhoff
South Florida
2024 SGP FL5
I like them, but 23.5lbs still seems heavy for an 18. I understand it is 0.5" wider, so will weigh a little more, but the other Titan 7 18s are running 18.3-20.9lbs for 18x9.5. 2.6 lbs for half an inch seems like a lot.
Status
