procivic
- Joined
- Jan 29, 2016
- Threads
- 71
- Messages
- 688
- Reaction score
- 144
- Location
- Ventura, California
- Website
- www.procivic.com
- Vehicle(s)
- 2022 Civic Si Sedan, Others
- Thread starter
- #1
When the Type R first came out, we were unsure if it would have similar power modification potential compared to the 1.5T engine. Well, I'm happy to say that those days are gone! With the Hondata FlashPro FK8 Civic Type R Flex Fuel software update and this new SiriMoto E85 Flex Fuel Kit, your Type R will see 65+ hp and 70+ lb-ft of torque using just the Hondata Base Map and some E85 fuel (at about E40 concentration).
Here are some key takeaways for the Type R version of this kit:
For the Power Package that includes a Hondata FlashPro, see here: https://www.procivic.com/p/m/civic/sirimoto-hondata-flashpro-e85-flex-fuel-power-package.html
Please keep in mind, this product is not designed for public highway or street use, and is only legal for formally sanctioned race use on a racing vehicle that may never be used on a public highway or street.
As always, let us know if you have any questions!
- Available Base Calibrations will provide peak performance between 25-40% ethanol (E25 to E40) concentrations. This is a general recommendation and your exact optimal ethanol % will vary depending on your other bolt-ons and if you use a custom tune or not.
- The FlashPro has a specific safety strategy for the Type R: boost will decrease as ethanol concentrations surpass 30% (E30) mixtures.
- Boost is reduced in this manner because the stock High Pressure Direct Injection Fuel Pump cannot supply the necessary fuel volume for full boost at E40.
- Allows you to run E85 fuel, and mix it with regular pump gas. Your gas tank is not required to just have all E85 fuel in it after installing this kit (hence the name Flex Fuel). The Hondata FlashPro will automatically adjust your tune on the fly as needed for your current fuel mixture.
- Potential for huge power/torque gain.
- Helps to spool a turbo earlier and faster.
- Allows the engine (and turbo) to operate considerably cooler.
- Enables the ECU to dynamically adjust your tune, for a given amount of ethanol percentage.
- Best bang for your buck power adder.
- Easily monitor your E85 / Ethanol-Percentage level with the included Innovate digital gauge.
- You can choose to run regular gasoline and only pump E85 when you desire more power/torque.
- This kit was thoroughly tested and designed with very reliable components.
- Easy to install and features pre-assembled fuel lines to plumb the Ethanol Sensor.
- Comes with comprehensive installation instructions.
- Covered by a 1 Year Limited Warranty.
- Custom SiriMoto Flex Fuel Badge included with every kit.
- Includes everything you need for a complete installation.Plug-and-Play (PnP) solution, does not require any splicing of wires.
- Premium Chasiss Harness constructed with:
- Tefzel Wiring
- Deutsch Connector
- Flame-Retardant Nylon Sleeve
- Sturdy Ethanol Content Sensor Bracket for lifetime reliability.
- Includes Gauge Pod to easily mount the Innovate digital gauge.
