Missouri sold
HECTOFL5TYPER
Hector
2025 TYPE R
Man I’m out here working. I’m tempted to buy the swift springs. How much does it lower the car by ?
PrecordFK7
Thom
2024 Integra Type S
sgreer78
sgreer78
St Louis
25 CW CTR
Heard your limited on how much extra negative camber you can get from the Ballade mounts. How much camber were you able to run with them?
I never personally used the plates. But the previous owner ran them at -2.5Âş.
Rexpelagi
John
Nashville, TN
www.youtube.com
Heard you're limited on how much extra negative camber you can get from the Ballade mounts. How much camber were you able to run with them?
@sgreer78 is correct regarding the ~-2.5° achievable with the plates. I'm actually the original owner of these, and I think with the pins pulled you'll get around -1.8°, so these will get you a bit more. The plates themselves can go more negative, however the lower spring perch on the stock shock body will hit the chassis if you go any farther.
FWIW, I found -2.75° to work best on my coilovers - more than that and the front tires can't put power down on corner exit and the inside of the tires wears out very quickly, so -2.5° is a good setting IMO. I know others have different experiences though.
PrecordFK7
Thom
2024 Integra Type S
I was wondering how much room there was before hitting the chassis. Sounds like you can get an extra -0.5° comfortably with these. Very good to know. I like the idea of having a little adjustment vs fixed 1° increments with the ball joints.
sgreer78
sgreer78
St Louis
25 CW CTR
I’ll make you a sweet deal for both!
