Stone Guard DIY
MKC
Bay Area
AggAuto Universal 40"x13" Car Grill Mesh 3x6mm Rhombic Holes
Black Gorilla Tape
Short flat head for the clips
The trick is to slide in the tab and wiggle gently.
Tried using two screw drivers and freaking broke the first clip
Dealer wanted 4.17 each! So I bought 4 then I figured it out how not to break it!Generic one works but I wanted OEM and right away so no choice…
if anyone interested in the mask I can scan and make it printable.
The one I got online is actually off had to make my own.
It looks ghetto but will turn out factory like.
11th Gen Honda Civic Stone Guard DIY A31B5F7A-610E-4811-921D-C3FC0F03FD9A
11th Gen Honda Civic Stone Guard DIY FF931E75-B267-4282-B007-2F708A391AF8
11th Gen Honda Civic Stone Guard DIY 19CC38DA-FC87-4137-8C97-506CFD6DED53
11th Gen Honda Civic Stone Guard DIY 6AFDB5B6-64D6-476F-AFF5-A496D69670F6
11th Gen Honda Civic Stone Guard DIY 34A43749-2FE0-470B-A3B5-2D54B7B97019
11th Gen Honda Civic Stone Guard DIY 19A40548-13B0-4361-AC79-B47130621918
jporter9
Jeff
Knoxville, TN
2025 Type R, 2016 Civic EX Sedan, 2019 Honda Odyssey Touring Elite
Any way you can send me the mask? I'm going to try having this 3D printed at work. Appreciate any help.
Eiching1
I thought about this as well. My concern is that it cuts down on airflow to the condenser
latole
Vaudreuil,Quebec ,Canada
The photo of the car does not show that this cannot be the case. The condenser remains very well supplied with air.
I would not have installed the mesh in this location, which is the subject of #1.
Look how thin the links between the cells are. Arrow
11th Gen Honda Civic Stone Guard DIY Capture d’écran, le 2025-10-02 à 04.17.18
11th Gen Honda Civic Stone Guard DIY Capture d’écran, le 2025-10-02 à 04.22.07
Eiching1
They are pretty thin, so probably an insignificant amount of reduction.
prc
CTR FL5, EG6
Black Gorilla Tape
Hi! Can you send me the mask? Thank you
theschwartz
Cody
2025 Honda Civic Type R
Hey @MKC , would you mind sending me the mask as well?
Thank you!
stnmntn
Atlanta
2025 CBP type r
@MKC can you share the scan please. I was about to tackle this and came across your thread. Thank you!
theschwartz
Cody
Here are some measurements, I’ll try to post a better template when I can.
For the clip holes, I just made them much larger as they didn’t quite line up at first, as you can see in the installed picture.
11th Gen Honda Civic Stone Guard DIY IMG_0429
11th Gen Honda Civic Stone Guard DIY IMG_0431
11th Gen Honda Civic Stone Guard DIY IMG_0435
11th Gen Honda Civic Stone Guard DIY IMG_0430
11th Gen Honda Civic Stone Guard DIY IMG_0432
11th Gen Honda Civic Stone Guard DIY IMG_0434
11th Gen Honda Civic Stone Guard DIY IMG_0433
11th Gen Honda Civic Stone Guard DIY IMG_0417
MrBBQ
Danny
A simpler design. Just the top and bottom clips are enough to hold it in place. Don't bother saving the plastic clips. They will break no matter how careful you are, even on a brand new car. I just bought a box of different sized clips on Amazon.
11th Gen Honda Civic Stone Guard DIY 1000046353
11th Gen Honda Civic Stone Guard DIY 1000046354
