27WON - Testing the OE Turbo Inlet Pipe
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
I like bed liner paint jobs. Adds class.
On a serious note, I do like the look of it.
Thank you, we went with a powder coat for the durability and to help keep it clean in the engine bay.
Hondanickx
Nick
Belgium
1998 civic hatch , 2018 White civic sedan
Looks great ,i Cant stop thinking about the heat soak this piece of aluminium has.
Did you did temp measurements on the tip as wel?
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
Anger
Nick
Greece
CR-V '19, HR-V '19
still tbd, price will be less than an intake, I know that much for sure.
Do you happen to know if it will fit the 5th gen 1.5T CR-V? Engine is the same, I guess the space is more than enough, just asking to be 100% sure
Hondanickx
Nick
Belgium
So 2hp gain on a si with stock turbo .How much are the gains on a non si with stock turbo?5hp?
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
from what we can see around 4, again the stock turbo is just so so small.
Hollywoo0220
Customer Service oriented (most of the time) :-)
RJ
WA
Tank, Lunar Module, and 1990 Diahatsu Charade
No issue with the Testing outcome. It was to be expected that a larger TIP would require a larger turbo. This will definitely entice many to upgrade.
Hondanickx
Nick
Belgium
Did you guys also measured the Temperature the TIP has?This still is a large piece of aluminium so i imagine it gets heat soaked pretty badly?Or Not?
Shadowfighter
Idaho
2017 civic hatchback sport manual
I'm guessing this is not going to work with my PRL race maf? :(
