UCF120
- First Name
- Jon
- Joined
- Feb 27, 2024
- Threads
- 7
- Messages
- 89
- Reaction score
- 51
- Location
- Orlando,FL
- Vehicle(s)
- 2023 Boost Blue Type R, 2002 S2000
- Thread starter
- #1
Got a wierd issue with my car that I’m hoping someone can shed some light on.
Car is a 23’ with 8k miles now. Has acuity cable shifter bushings and Hasport 62a RMM. For the most part, my transmission shifts pretty smoothly. 1-2 is always smooth and I’ve never once had a grind. In fact, I’ve never grinded any gear.
However, I do have an odd sensation in the gear knob when downshifting from 3-2. There’s no grinding noise or any noise at all associated with it. But occasionally, mostly when cold but even when hot, I’ll get this “Buzz” sensation in the gear knob when first hitting the gate going from 3-2 only. I’ve turned auto rev match off and the sensation actually happens less with it off but it still happens.
I don’t get locked out of gear, there is no grind, and it goes into gear smoothly every time after. It’s the oddest thing and I’ve never felt it before on any car. It’s almost like a small shock type feeling in the gear knob when initially hitting the gate going from 3-2. Like it almost wants to grind but doesn’t.
I recently changed tranmission fluid from the factory fill to Amsoil 75w-90 transmission and transaxle gear lube. The sensation was present on both fluids. The Amsoil has slightly improved hot shifting but cold is about the same as factory I would say.
Anyone experiencing this or have any insight?
