Missed shift 3rd to 2nd with resulting added NVH
CTR
WA
strixauto.com
2023 Civic Type R, 2020 GX460
It's starting to get warmer outside. The engine vibrates a lot more when the AC is running. This could just be a coincidence?
As others have said learn proper hand placement so it doesn't happen again.
jcm
LA
2025 SGP FL5
it's a good point but all testing is conducted with A/C off. this includes datalogging as a result of extended drive period.
jcm
LA
2025 SGP FL5
update:
cylinder 1 - EWMA (weighted moving average) misfire counts - last 10 driving cycles - 4
cylinder 1 - Count for Last/Current driving cycle - misfire counts - 6
cylinder 2 - EWMA (weighted moving average) misfire counts - last 10 driving cycles - 4
cylinder 2 - Count for Last/Current driving cycle - misfire counts - 5
cylinder 3 - EWMA (weighted moving average) misfire counts - last 10 driving cycles - 5
cylinder 3- Count for Last/Current driving cycle - misfire counts - 3
cylinder 4 - EWMA (weighted moving average) misfire counts - last 10 driving cycles - 6
cylinder 4 - Count for Last/Current driving cycle - misfire counts - 2
will be putting the car in tomorrow as soon as possible. updates to follow
Small, random, misfires are normal. All engines misfire to some degree, simply because the combustion process and timing isn’t 100% perfect at all times, under all conditions. An actual, serious, misfire will cause a CEL…and the sensors in these cars will definitely pick it up quickly. I think you may be driving yourself crazy with over analysis dude.
Starchland
Jeff
Toronto
Honda s2000
Does the log show actual rpm?
road speed was 65 max in 2nd? Not an issue
Tougefl5
Banned
Banned
It's crazy that so many people have issues shifting these cars. Almost every other month a new thread about it.
dandaman15
Milwaukee, Wi
2014 RDX, 2023 Type R
I can almost guarantee the engine is fine. There's not going to be any bearing issues from this, its not like you spun it to 10k rpm lol.
Did you look under the car and check the RMM or any other mounts to see if the sudden jerk loosened anything up? A money shift adds a ton of stress to the mounts and can tear/loosen up the rubber.
jcm
LA
2025 SGP FL5
Have not checked rmm yet it was set at specced 69 lb/ft iirc I'll have to check it.
The good news is that I'm still on the next step of oil analysis and this far hVe been unable to recreate the noise issue
elcid79
J
Various
If you did money shift. Replace your springs. It’s not overly expensive and can save you trouble. Could be as simple as that.
  • Like
Reactions: jcm
jcm
LA
2025 SGP FL5
also I did a very correct breakin I've changed oil several times by 5k so when I get the oil reading any lack or presence of solids in the oil based on that will be an indicator clear as day. It's not looking too bad as of now after ongoing monitoring
TheFactor
Factor
So Cal
2025 CW Civic Type R
It’s driver error not the FL5’s fault . I’ve done it also and not just with the FL5. I’m not a pro but just a seasoned track day guy .
It happens ????
jcm
LA
2025 SGP FL5
violent noise came back yesterday wish i could capture it, my phones have shit audio so i can't despite trying... if i could show you guys a clip you'd understand the concern... the noise at 1600 rpm is voilent
Tougefl5
Banned
Banned
Are you launching your car from a dig? It’s your car do as you wish. I'm just trying to figure out how on earth your getting pulled in any direction when VtecTurbo hits lol
So, it’s inconsistent? It went away, then came back? This doesn’t make any sense…at least not with respect to potential engine damage. Someone else mentioned checking your motor mounts. Have you done that?
