4 point harness
HONDANB
JOHN DOE
FL
NEEDED
I assume to the stock mounting points. 2 on the back 2 stock mounting points total 4 point harness
So this looks like mounting points for the lap belt only.
Anyone know if it’s possible to use the children car seat latches in the back seat to secure the shoulder belts?
HONDANB
JOHN DOE
FL
NEEDED
Judging by the pics, those adapters would be more like for the shoulder straps and the belt straps would use the stock mounting points.
Looking at Schroth install guide, the shoulder belt should be parallel or at most 20 degrees lower. So anchoring to the back of the driver seat shouldn’t be done.
I’m also trying to use my existing hans neck restraints but it looks like without a harness bar, it shouldn’t be used either. So the stock seat belt it is. Unless someone knowledgeable with safety restraints can chime in.
mparra11
miguel
ohio
type R
Anyone make a harness bar yet?
