Harness or harness bar
kidsao
Steven
Socal
FL5 DC5
any of you running a 4 point or 5 point harness on your stock seat? if so, how are you mounting it? anybody running a harness bar that isnt a cage?? need help.
Xian
Christian
Saint Augustine, FL
Model Y Performance, Lotus Elise
As good as the stock seats are (assuming you lock the seat belt), I don’t see why you’d need multipoint belts for Autox, DE, or even mild-prep TA. If you’re going fast enough to justify the belts, you’ll also be going fast enough to need a roll bar.
kidsao
kidsao
Steven
Socal
FL5 DC5
im sliding off the seat during track day
g0al3d
Brian
SOCAL
2025 Type R (Championship White)
you need to eat a sandwich or something? jk :) in all seriousness you must either be pushing REALLY hard or something else is going on, i just came back from the track and i had no problems and I was putting in some relatively good times. I only have 5 points in my caged race cars.
Xian
Christian
Saint Augustine, FL
Are you locking the seatbelt* before going out on track?
*slide the seat back a little extra, pull the belt tight across your hips/chest, give it a quick pull at the shoulder to “lock”, lean into the belt, pull the seat forward (I hook my feet under the clutch/brake pedals) until the belt is holding you tightly into the seat.
