optronix
- Joined
- Apr 5, 2023
- Threads
- 2
- Messages
- 689
- Reaction score
- 1,017
- Location
- Mid-Atlantic
- Vehicle(s)
- 2024 Integra Type S, 2023 Macan GTS
The DWS06 are a great all season tire. But they do not compare to the PS4S for grip or road feel.
Here in the mid-Atlantic our winters can get quite cold, and while I don't have a necessity to drive in snow, I do need my car when it's below 40 degrees, which is generally not advisable to be driving on a summer tire. So I love the DWS06 for that- there isn't too much of a compromise vs the PS4S.
But I swapped back to the Michelins in April, and noticed a very clear and distinct difference right away. I do autocross my car and wouldn't consider the DWS06 at all for that, but even on the street I vastly prefer the Michelins.
This is where you need to ask yourself what your plan for the winter is. You didn't mention a location, so I'm not sure if you're going to attempt to drive on summer tires in the winter months if it routinely dips below 40 degrees. I wouldn't recommend it. In the northern states, all seasons would be the minimum- I'd actually consider a set of dedicated winter tires for the colder months.
If you don't want to deal with swapping out tires, and don't really value the extra confidence and feel you get from the Michelins, then sure, the DWS06 are a very good option. You could also consider the Michelin A/S4, arguably an even better all-season option that probably would be available in a good size for 18s (they're not available in OEM 19" sizes which is why I chose the DWS06).
But if you want to maintain the grip and feel of the car as it came from the factory, you should strongly consider maintaining a summer tire. For that, the Extreme Sport 02 is the equivalent of the PS4S. Might be a little cheaper, and many folks have claimed they like them- but I think in most practical tests they are still the inferior option to the Michelin.
As others have stated, stay away from any of the 200 treadwear options. You can even get away with doing track stuff on the PS4S- only consider an "upgrade" to 200 TW if you're concerned with going faster in timed events. For almost all other use cases, the "normal" summer tires (e.g., PS4S) will be the better option.
