Aftermarket windscreen glass using OEM seals
r513ctr
Sydney, Australia
Honda Civic FL5 Type R
Hi there,
So I've recently copped a couple of stone chips to my front glass and after going back and forward with my insurer I've just decided to get an aftermarket replacement, after talking to the company who's doing the windscreen (O'Brian) they have basically said that they will install the aftermarket glass with aftermarket seals and what not.
My question is would the OEM seals be compatible with the aftermarket glass as I've heard that it's generally thicker? From what I can see on the front window assembly there are 3 seals required numbered 4, 8 and 5 as per below.
11th Gen Honda Civic Aftermarket windscreen glass using OEM seals 1000041583
https://dreamshop.honda.com/s/category/honda/0ZG6g0000004HolGAE
I'm presuming when the pull the factory glass the seals listed are unusable?
Any information would be appreciated, cheers.
r513ctr
r513ctr
Sydney, Australia
The CTR and regular hatch use the same seals. Even though the windshields are marginally different
Oh ok that's good to know, regarding the items listed in the diagram are all needed for the glass replacement or just the seals?
nttran98
Nhan
2026 FL5
I honestly would confirm whether its fuyao or not with the glass installer and get the solar acoustic one. The FL5 does not come with neither for weight saving that I think is negligible.
On my second windshield and it has 2 chip repairs. I'll request the thicker, solar glass when it comes time.
The installation company went by the FL5 serial number for the previous replacement (OEM glass). I confirm the FL5 glass looks very thin having bird-dogged the tech. I won't notice the weight difference of thicker glass.
r513ctr
r513ctr
Sydney, Australia
Yeh I contacted and asked what the replacement will be, this was their reply
Manufacturer/brand and country - Xinyi (China)
Manufacturer part number - CIVIC-22-R-SZ LFW/X
DOT code - DOT563
Yes, this glass is a like for like replacement
Specifications of AE glass:
Technical Description;
Drop Down Band/ Fitting Sensor/ Glass Colour-Green/ Acoustic/ Silkprint 4/4/ Right Hand Drive only/ Silkprint Brackets and / Or Fittings/ ADAS Systems.
nttran98
Nhan
2026 FL5
DOT code - DOT563
can you see if they do fuyao?
r513ctr
r513ctr
Sydney, Australia
I asked the question and they said they only stock Xinyi glass for the FL5 Type R. I know a few ppl who run the glass from O'Brian and have had no issues, my only concern really is the seals and whatnot being used. I think I'll just purchase them from Honda myself and provide them on day of installation.
DOT code - DOT563
Right hand drive only? Are you in the UK or former colony?
  • Haha
Reactions: J_D
