why did you leave? did they fire you so they can pay someone less? what's your opinion on build quality these days? did you get to buy cars straight from the plant?I just ended my job at Honda. If anyone has questions about AEP, I'll do my best to answer them.
also, my clutch always felt a bit off since new. how accurate are they adjusting clutches?
1.5, 2.0, and whatever the v6 is.What engines other than the K20C variants were built there. Was the an indication they were moving away from those engines to something new?
I have heard that the K20C1 found in the FL5 is produced at that Plant, i guess you can confirm that?I just ended my job at Honda. If anyone has questions about AEP, I'll do my best to answer them.
I can indeed confirm that the K20C1/C8 is built at AEP.I have heard that the K20C1 found in the FL5 is produced at that Plant, i guess you can confirm that?
Do you know if Honda has other Plants producing this engine aswell?
good luck with your new job btw
