Anna Engine Plant
34631-fk8
2019 Civic Type R
I just ended my job at Honda. If anyone has questions about AEP, I'll do my best to answer them.
onepointsix
Toronto
TW FG2 & SGP FL5
Sorry you left your position, particular reason why? Where on the line did you work?
why did you leave? did they fire you so they can pay someone less? what's your opinion on build quality these days? did you get to buy cars straight from the plant?
also, my clutch always felt a bit off since new. how accurate are they adjusting clutches?
J_D
J
Montreal
Plant only makes engines, not cars. He can't help ya there
34631-fk8
34631-fk8
2019 Civic Type R
Found a higher paying job elsewhere.
I did not work on the line. I worked in facilities, access to the whole plant.
onepointsix
Toronto
TW FG2 & SGP FL5
What engines other than the K20C variants were built there. Was the an indication they were moving away from those engines to something new?
34631-fk8
34631-fk8
2019 Civic Type R
1.5, 2.0, and whatever the v6 is.
They are in the construction phase of preparing to manufacture the IPU, the case that surrounds the battery in Honda BEVs.
Stocki011
Markus
Austria
white FL5 Type R | Fiat Tipo 1.4 T-Jet | red Alfa Romeo 159 1.8 TBi sold
I have heard that the K20C1 found in the FL5 is produced at that Plant, i guess you can confirm that?
Do you know if Honda has other Plants producing this engine aswell?
good luck with your new job btw :)
34631-fk8
34631-fk8
2019 Civic Type R
I can indeed confirm that the K20C1/C8 is built at AEP.
Possibly, but the vast majority are built at AEP.
Thank you!
