Buzzing noises when driving between 30 and 60 miles per hour?
juanfiandro
Juan
Asunción Paraguay South America
CTR fl5 '24
Is it just me, and does the car make those noises?
But when I drive at those speeds on the highway, it's like the wheel bearings are really noisy.
I don't know if the soundproofing is too poor, or if the wheel bearings are already making noise—I mean, a humming sound.
The car has 15,000 miles on it.
Especially when I'm not accelerating and the car is in gear.
Is there any way I can rule this out? Or is this the normal noise?
cryptolime
Wilmington, NC
i noticed the same thing when i first got my Si. sounded like some sort of harmonic resonance around 37-43 mph. probably a combination of the stock tires, and gears/LSD breaking in. don't really notice it much anymore since switching to Conti tires.
can you get a sound clip to see if we are talking about the same noise? mine was pretty faint...doubt it'd show up on a recording inside cabin.
ModJPB
Jason
There's two ways to diy check if the hub bearings are going bad.
1) while cruising at those speeds, do a very slight left or right motion. Usually if the bearings are bad you'll notice the noise changes as more or less weight is on each side. Now you're down to a 50% chance of knowing which bearing is bad.
2) Use wheel chocks, with parking brake off and car in neutral. Jack a suspected corner up. Gently rest one finger on the suspension coil spring. Use the other hand or a friend to spin the wheel freely. If the bearing is bad, the grinding will transfer a noticeable vibratition feeling in the spring. If unsure try the opposite side for a difference in feel. It would be extremely rare if both sides went bad at the same time.
juanfiandro
juanfiandro
Juan
CTR fl5 '24
Thank you so much.. good suggestions
