Does this sound like a throw out bearing noise?
89Sem
Sean
Philadelphia area
2026 Honda Civic Type R
When I press the clutch in the noise goes away might be hard to tell from the video it’s not obnoxiously loud just a steady chatter somewhat sounds like a throw out bearing noise. Car only has 700 miles on it not sure if it’s just a normal noise on this platform. Also when taking off in 1st gear 1,700rpm or so it sounds chattery sometimes more than others.
marcusm86
Marcus
Missouri
2025 Civic Type-R
sounds like a throwout bearing from what i hear.. hard to tell tho. id def take it in.
Bad throwout bearings generally make whiring noise with the pedal pressed (clutch disengaged).
I find it normal to hear more transmission noise in neutral with the clutch engaged in a variety of cars and motorcycles. Without load, the gears slap around a bit due to engine firing pulses. It doesn't hurt anything.
89Sem
89Sem
Sean
Philadelphia area
Appreciate the input, my last manual transmission in a car was 15 years ago and I did have a bad throw out bearing but it’s hard to recall the sound I just remember the symptoms were similar. On motorcycles it’s much harder to tell with all the different engine noises and components in such a small area.
jtlctr
Jake
I have had the same noise and under the same conditions for as long as I can recall (27k on the odo now). I think what we are hearing is just gearbox chatter since there’s no load on anything in neutral, and we have a lightweight, single mass flywheel that does nothing to dampen those sounds. I wouldn’t worry about it.
