Dust Boot Cooked!!
ttccnn49
Steve
florida
Street triple 765RS
noob question... so if I want to replace the dust boot, is it as simple as remove the old boot and put on new ones?
FL5golfer
FL5golfer
I'm probably going to go with the Girodisc dust boot kit:
Girodisc Dust Boot Evasive motorsports
Just ordered a set of new pads too. I Currently have Project Mu Clubracer pads on my car. Tried ordering another set, but it's on backorder.
Going to try Paragon R5 front / Paragon P3 rear
Deleted User 3888
One cool thing I noticed about paragon pads. Helped my brother in law do a set of p3’s front and rear. Their backplates are super thin and basically adapt to shims with zero drama and zero pad instability issues. I’m sure you’ll like the combo.
FL5golfer
FL5golfer
It's pretty straightforward when I did it. It's easier to change them when the pistons are sticking out. Use a pick to pry out the old dust boots, then slip on the new dust boots. I removed the rotor and bolted the caliper back on so that I can work on removing the old boots and installing the new ones. Removing the caliper completely is not necessary.
This video helps:
