Feel no difference between 19.5 and 23
Yaminashi
Cincinnati, OH
91 Integra DB1, 18 Civic Si
I have the dual tune on my Si and it honestly doesn't feel any different putting it back and forth. Did a 0-60 in both modes and came to same times also have looked at the in car boost gauge and it peaks out at about 17 psi. I know the car still looks for the right parameters but I still feel like I should feel a difference between the two tunes.
Masked
Jos
Quebec, Canada
'18 Civic Si Coupe
Peaks at 17psi in sport mode? Mmh check for boost leak, also do you have a datalog?
gtman
Mitch
2017 Cosmic Blue EX-L Sedan
Don't go by your stock boost gauge. Hook up your KTuner and run a datalog as suggested above. No way your boost should peak at 17 psi on those tunes.
Yaminashi
Yaminashi
Cincinnati, OH
I'll try and get tunerview up and running to see what it says my boost is at.
Design
09 MS3, 17 ABM Si Sedan
Even the stock boost guage should show a significantly higher PSI readout above 4K RPMs... at least in 3rd gear and above.
Question: Did you configure the map switching options in the desktop software?
11th Gen Honda Civic Feel no difference between 19.5 and 23 drex_on_the_fly_map_switching_custom
Yaminashi
Yaminashi
Cincinnati, OH
The only thing I did was check the options for turbo responsiveness.
Design
I suggest manually setting your normal/sport boost targets for all three maps - even if each map would have the same parameters.
Yaminashi
Yaminashi
Cincinnati, OH
Reflashed the car today with the same tune and selected the boost targets for normal and sport, still getting peak psi at 17.5 for both tunes from the car and on tunerview.
gtman
Mitch
Boost leak somewhere it would seem.
Run a full datalog and do some WOT pulls and upload it here.
Design
Did you update your software parameters as suggested? Or do they still say custom level?
Yaminashi
Yaminashi
Cincinnati, OH
I updated them as suggested. I'm going to run two separate datalog files tomorrow, one for the 19.5 and the other for 23.
gtman
Mitch
No need for two datalogs. Just do half the drive at 19.5 and the other at 23.
Yaminashi
Yaminashi
Cincinnati, OH
You're not on a tune. You likely uploaded to the unit instead of flashing or failed a flash and recovered back to factory.
Thanks, glad I'm pretty dumb. I'll try it out tonight.
