FL5: Do not see clutch reservoir
NorCal
EG6, S2K, Suburban, CB650R
Title: Or perhaps this car has the brake and clutch fluid the same reservoir.
Leonidas I
Leo
Greece
17 Civic HBS, 22 Civic HB ST
Yep same res, just changed my brake fluid last month and figured that out too. :)
Spart
2025 Integra Type S
There's a tube going from the brake MC reservoir to the clutch MC.
It's set up so that if you're losing fluid for some reason with the clutch, the brakes should not run out of fluid due to how high the tube going to the clutch is on the MC reservoir.
So if you're bleeding your clutch, pay attention to that and do not allow the level to drop below that tube on the brake MC reservoir or you'll start admitting air into the system.
Another Motorist
NorCal
Interesting, so there is still a clutch mc. Is it somewhere behind/under the battery?
I might just give it a lil bleed, curious to see what comes out.
2025 FL5 Civic Type R
The clutch master cylinder is under the battery. There are a few videos online of people replacing them, but bleeding the clutch is towards the front of the car from the clutch slave.
Spart
2025 Integra Type S
What are you trying to accomplish exactly and what prompted this?
Another Motorist
NorCal
New owner, looking around. 3rd day with this car. I change my clutch fluid regularly on all my cars for the past decades.
