Mangoal
North America
2024 Maverick XLT
Hi everyone,
Just wanted to introduce ourselves—we're the tech support team at Mangoal Dash Cam, glad to officially join the CivicXI community!
We're mainly here to help with any tech questions or troubleshooting, and to hook you guys up with exclusive forum discounts.
We know many owners here care about clean OEM-style installs and making sure everything works smoothly without dangling cables.
I've attached a quick frame grab from our setup video showing a detailed view of the connection point on the factory Honda mirror component.
If you'd like to see the full step-by-step installation process and how it looks inside the cab, check out our walkthrough video here:
Mangoal
Mangoal
North America
2024 Maverick XLT
This looks incredibly similar to fitcam, what's the difference?
Good question! While both use integrated OEM-style housings, the main differences are under the hood:
  • Sensors: We use genuine Sony STARVIS sensors (including STARVIS 2 options for better night vision) instead of generic sensors.
  • Internal Thermal Design: Ours uses an aluminum alloy core inside for better heat dissipation under direct sunlight, which helps stability during long drives.
  • Internal Wiring: Full FPC flexible ribbon cables inside to keep things reliable over rough roads.
  • Built-in GPS: Comes standard on our models.
So the outer housing fitment is basically the same, main difference is just the sensor and internal thermal setup. 👍
I already have a viofo so not in the market but I remember looking at the fitcam and not being impressed with the quality at all, it looked like crap. The viofo I have is pretty decent, has the starvis 2 chip as well.
