Mangoal
Chris
North America
linktr.ee
Hi everyone,
Just wanted to introduce ourselves—we're the tech support team at Mangoal Dash Cam, glad to officially join the CivicXI community!
We're mainly here to help with any tech questions or troubleshooting, and to hook you guys up with exclusive forum discounts.
We know many owners here care about clean OEM-style installs and making sure everything works smoothly without dangling cables.
I've attached a quick frame grab from our setup video showing a detailed view of the connection point on the factory Honda mirror component.
If you'd like to see the full step-by-step installation process and how it looks inside the cab, check out our walkthrough video here:
Mangoal
Mangoal
Chris
North America
linktr.ee
This looks incredibly similar to fitcam, what's the difference?
Good question! While both use integrated OEM-style housings, the main differences are under the hood:
  • Sensors: We use genuine Sony STARVIS sensors (including STARVIS 2 options for better night vision) instead of generic sensors.
  • Internal Thermal Design: Ours uses an aluminum alloy core inside for better heat dissipation under direct sunlight, which helps stability during long drives.
  • Internal Wiring: Full FPC flexible ribbon cables inside to keep things reliable over rough roads.
  • GPS Module: Comes standard on our models.
So the outer housing fitment is basically the same, main difference is just the sensor and internal thermal setup. 👍
  • Built-in GPS: Comes standard on our models.
I already have a viofo so not in the market but I remember looking at the fitcam and not being impressed with the quality at all, it looked like crap. The viofo I have is pretty decent, has the starvis 2 chip as well.
evlsmurf
2016 Subaru Impreza Sport
Your website says the 11th gen is sold out...
Mangoal
Mangoal
Chris
North America
linktr.ee
Just checked on this—the 11th Gen version isn't sold out, it's actually fully in stock!
What's showing sold out on the site is actually the discontinued 10th Gen STARVIS 2 model. You should be good to order the 11th Gen version without any issues, but let me know if you need help finding the right link or checking fitment! 👍
Standard: https://mangoal.com/products/mangoal-front-dash-cam-for-honda-civic
Starvis 2: https://mangoal.com/products/front-4k-hdr-dash-cam-starvis-2-for-11th-honda-civic-black
evlsmurf
I put the standard 11th gen in my cart, hit checkout and got a message saying it was out of stock...
Mangoal
Mangoal
Chris
North America
linktr.ee
Totally fair—Viofo makes great hardware and their STARVIS 2 setups are top tier.
I agree on some of the older OEM-style housings looking cheap. We spent a lot of time tweaking our shell texture to match factory trim and adding an aluminum core inside so it doesn't feel like budget plastic or overheat in the summer.
Standalone cams are awesome, but the clean zero-wire setup is really the main appeal for this style!
Mangoal
Mangoal
Chris
North America
linktr.ee
My bad on that! That was a backend inventory glitch on our site. Just fixed the stock numbers, so you should be good to check out now.
Let me know if it gives you any more trouble! 👍
Graffix3001
2026 Civic Si
I can vouch for Mangoal here. Quality of the video is very good. And that OEM look is what I really like.
I have the Starvis 2 version with front 4k and rear 2k. I do wish they had a 3 channel version to get front, rear, and driver.
Install was very easy as well.
Mangoal
Mangoal
Chris
North America
linktr.ee
Appreciate the vouch, man! Glad to hear the 4K/2K setup and install went smoothly on your Civic.
Duly noted on the 3-channel setup with the cabin camera as well—that’s super solid feedback for our product team. Thanks for sharing! 👍
CivR
Chris
Washington
do you have an app to connect? Does that app have adds or require a paid sub? Is it user friendly and how robust are the settings?
Mangoal
Mangoal
Chris
North America
linktr.ee
Yes, we use the SkyCamm app on both iOS and Android.
There are no ads or paid subscriptions, so the app is completely free.
It’s pretty straightforward to use. You connect to the dashcam over Wi-Fi to view live footage, download clips to your phone, or change settings. There are actually quite a few settings you can adjust, including video resolution (4K/2K/1080p), loop recording length, G-sensor sensitivity, time-lapse parking mode, audio recording, and SD card formatting.
One thing to keep in mind if you use Wireless CarPlay or Android Auto: switching your phone from CarPlay’s Wi-Fi connection to the dashcam can temporarily disconnect CarPlay, and sometimes it will try to reconnect automatically. If that happens, turning on Airplane Mode and then re-enabling Wi-Fi usually makes it easier to connect to the dashcam.
The camera records automatically whenever the car is running, so you really only need the app when you want to pull footage or change settings.
Here's a full walkthrough video showing the app layout and settings if you want to check it out:
