Honda civic 1.5t dipstick check
ahmunife
ahmunife
honda civic fe 2022
After driving for 10 minutes and the engine was fully warmed up, I stopped my car and waited 2-3 minutes before checking the oil level. Is this normal?
11th Gen Honda Civic Honda civic 1.5t dipstick check IMG_1489
11th Gen Honda Civic Honda civic 1.5t dipstick check IMG_1491
V3N0M_VZL4
Mauricio
Miami, Florida
2022 Civic SI
Looks low to me should be in the middle of the 2, but I prefer in the upper line.
ahmunife
ahmunife
honda civic fe 2022
I'd love to have a technician come and review it. It seems to me that it's exactly where it needs to be right now.
I see it at the upper limit right now.
I agree, looks fine. This dipstick design sucks and can be hard to read. (Thanks Honda)
ahmunife
ahmunife
honda civic fe 2022
It is the result of me thoroughly cleaning and checking the stick.
ahmunife
ahmunife
honda civic fe 2022
I agree, reading really sucks
ahmunife
ahmunife
honda civic fe 2022
This is the result of checking when the engine was cold. In the other image I shared before, the level was slightly lower when the engine was hot.
11th Gen Honda Civic Honda civic 1.5t dipstick check IMG_1509
11th Gen Honda Civic Honda civic 1.5t dipstick check IMG_1508
ahmunife
ahmunife
honda civic fe 2022
Do you think I have reason to worry? Everything seems to be as it should be.
ahmunife
ahmunife
honda civic fe 2022
This isn't an engine coolant measurement. What you mentioned applies to the water measurement. The situation is the opposite with engine oil. In a cold engine, the oil level is completely at the bottom, so the dipstick shows a high level.
Gansan
Glen
San Diego, CA
1999 NSX, 2024 Civic Type R
Just to confirm what you did, you:
1. Pulled out the stick and wiped the oil off.
2. Put the stick back in.
3. Pulled it out and held it horizontally.
If so, then the oil level looks like it's at the top of the range. Don't worry about it.
ahmunife
ahmunife
honda civic fe 2022
I took both measurements when the engine was hot and cold, as you stated. I added the measurements. Do you think both are normal?
