Hondanickx
Did anybody used the traction control yet with the +6psi tune ?
The carb version is best for people in CA. For anyone else, other than the slight cost savings..... doesn't make sense to have a limited version of the product.@gtman so how much miles were on the car when you added the tune and how much miles do you have now? I been stuck on this form debating if I should get the carb version . Flash and forget, or get the ktuner and just reflash when needed too...
Make sure your prl intake is in fact a "race maf" version, if its not then do NOT select the prl intake "mod" in the software. As that is only for the race maf version.Total noob, when it comes to tuning. I have a a question is there any boxes I need to check or uncheck prior to uploading my tune?Do they need to be messed with? Or just uploading the base map itself will suffice? I uploaded the +6 tune w sport mode on, when the vehicle is turned on. I just purchased flashpro a few weeks ago. This would be my first ever mod. Also just installed my prl Cai intake. The only thing I've messed around with is on the mods tab selecting the prl intake. And unchecking the boost error code, and Rev hang. Any help would be much appreciated.
Yes my intake Is the race maf.Make sure your prl intake is in fact a "race maf" version, if its not then do NOT select the prl intake "mod" in the software. As that is only for the race maf version.
What should Ideak fuel trims look like? I'll run a data log after work today and post back here when I'm done.^ Sounds golden to me.
One thing you may want to do is run a datalog just to double check your fuel trims.
Less than 10% combined trim so 5% ltrim and 5% strim is considered as close to "ideal" as most will get.Yes my intake Is the race maf.
On my break this morning I reflashed my vehicle to stock. Uploaded the +6 base map didn't mess. With the calibration settings only checked the box for my prl intake in the mods tab. Will this tune work ok without messing with the calibrations window?
Sounds good thanks for the reply, Im just trying to get familiar with the hondata platform and tuning over all. Will upload my data logs when ready. Thanks for all the quick responses much appreciated!Less than 10% combined trim so 5% ltrim and 5% strim is considered as close to "ideal" as most will get.
Yes it will work fine.
Here's a datalog, if anyone is willing to look at it much appreciated.Less than 10% combined trim so 5% ltrim and 5% strim is considered as close to "ideal" as most will get.
