It fits!! Painted Boost Blue CTR engine cover (NEW pics inside! 6/16)
Newskoolhonda
Alan
St. Augustine, FL
‘22 Civic Sport Hatchback
That looks awesome, I have had your exact same plan but in Platinum White Pearl. It look absolutely awesome, and totally take away any potential “Type R poser vibes” 😎
I had a few questions:
1) Did you sand/scuff the original red paint? Or use any primer?
2) How much paint did you use? (as in, one can etc.)
3) Did you clear coat the final product?
zeroptzero
Joey
Ontario Canada
That looks fantastic, nice job, and good idea going blue. I like red but not if it isn't on a CTR, so boost blue is legit. Good work.
sgtmorph
sgtmorph
Long Island, New York
Thanks everyone!!👍🏻
1. You absolutely should scuff up the surface, clean it, then prime it.
I however, did not! 🤣🤣 I quite literally just took it out of the box, taped it off, and sprayed the base color. “Full Send!”
2. I did about 5-6 coats and probably used 60%~ of the can.🤷🏻‍♂️🤷🏻‍♂️
3. No clear either. I really just did this as a test to see if it holds up as is. Just checked and it looks exactly the same lol. No deformations or other issues. And if it does go to shit…I start over and sand, prime, base, clear, etc. next time if that becomes necessary.
Newskoolhonda
Alan
St. Augustine, FL
Thanks everyone!!👍🏻
Do you still have you other one for sale? (What state are you in)
also, is you/your car on Instagram?
sgtmorph
sgtmorph
I had our parts dept order 3 of them, so now there’s two sitting there, so yes sir, I can get you one asap if you’d like.
In NY, but I’m not on IG.
Send me a DM here if you need 👍🏻
sgtmorph
sgtmorph
they come red from factory yes. I don’t have the part number anymore tho. Sorry but I threw out that box a longgg time ago
rallyeredpep
malvin
Philadelphia p.a 19124
2022 honda civic sport
12500-5BF-A03 this is the part ## I got by researching I hope it's the correct one and thanks for the update and research it's greatly appreciated...
rallyeredpep
malvin
thanks a lot and the A01,A02,A03 are basically the same part# I guess because if I look up either ine of those they all come up in honda dealer search well at least on my closest dealer..
