KTuner V2 Mounts
bry4nhdz
Bryan
2022 Honda Civic Si
Im only posting this because I was looking for KTuner V2 mounts and found that there aren't many to choose from. I realize that you can simply just look for Dual T mounts but it's usually the suction cup mount which I personally don't like. With that being said, I'm posting the two that I have that I like alot. One for every day use, and another that I usually use for my phone on a daily bases but I mount the KTuner there on track days.
11th Gen Honda Civic KTuner V2 Mounts IMG_3529
This one I usually have my phone mounted too, but its perfect fro track day use. Its at perfect height where it doesnt block the view but is also very readable especially when on the track. This mount requires you to already have the windshield mount as you will have to remove the Dual T mount from the knob and put it onto here. The link for this mount is here.
11th Gen Honda Civic KTuner V2 Mounts IMG_3525
This mount is completely out of the way and sits very comfortably under the vent. This one does require you to take off some pieces in order to install but it doesnt take anymore than 15 minutes. I use this on a daily bases since its alot further form eyesight, and I will be honest, the steering wheel block the right side of the screen a bit, but not too much. The link to this can be found here.
Websitesdown
I had mine located on the left side there on my 19si. I just used really strong double velcro tape and it never moved. Stuck it right on that fake carbon fiber. It didn't damage it at all either.
bry4nhdz
Bryan
2022 Honda Civic Si
Its clear thats the best overall ? any chance you can send the 3D print file?
