Need help removing trunk tray
hhkb
civic
Hello -- I am requesting help on removing an interior item. The picture below shows the two trunk tray mounting points:
11th Gen Honda Civic Need help removing trunk tray 2023_Civic_TypeR_0020.1
The underside of that section looks to have these "one-way" plastic clips (picture taken from a spare part):
11th Gen Honda Civic Need help removing trunk tray IMG_3839
I am attempting to remove this entire trunk tray but these clips won't budge. How do I remove them? Thank you in advance for the help!
Snmtazz70
Type R
The two metal hooks for securing on each side have a plastic cover, lift up with a screwdriver, then there's a phillips head screw that needs to come out. After that cover can be carried out.
Hope that helps.
hhkb
hhkb
civic
Hope that helps.
Is this the piece you’re mentioning? Is there a specific angle I should be prying up from? I’m using a plastic pry tool and giving significant force and it’s not popping off. I anm afraid of breaking the piece itself.
11th Gen Honda Civic Need help removing trunk tray IMG_3840
Snmtazz70
Type R
Lift the hook up, there's a very small cut out in the plastic to fit a screwdriver to pull up and get Phillip screw.
