Nuts in my air box !!!
pfmusician
Pat
Pennsylvania
2022 Honda Civic Tiuring
I’ll check into getting the spray. Is it something that’s available on Amazon?
Bpebler
Bobby
St Louis
21 Ram, 20 Durango, 00 Cherokee, 99 Trans Am
I’ll verify tomorrow the one I actually have to make sure I’m getting you the right info. The one that looks similar says it has coconut oil blended with it, but I’m fairly certain mine says 100% oil. I usually spray roughly once a month in the colder months.
pfmusician
Pat
Pennsylvania
For those that are interested - this is what I did today. Let's see if it keeps the furry little bastards out of my air box. Now, how to keep them out of my cabin air filter area???
11th Gen Honda Civic Nuts in my air box !!! Today
Bpebler
Bobby
St Louis
Here’s the one I’ve been using successfully. Turns out it does have some coconut oil in there, but that may actually help with keeping it to stick to the surface a little bit perhaps. ??‍♂
11th Gen Honda Civic Nuts in my air box !!! IMG_2487
11th Gen Honda Civic Nuts in my air box !!! IMG_2488
pfmusician
Pat
Pennsylvania
Thank you very much for your time and trouble. I will definitely check it out!
Bpebler
Bobby
St Louis
No problem at all man, just hope it helps! Fortunately I’ve only found nut remnants on top of my battery blanket & around the oil fill area ? been dousing it ever since lol I tried dryer sheets & moth balls before also in my Jeep. Dryer sheets don’t last & moth ball smell will seep into the cabin. Ugh it’s disgusting. Potentially harmful from what I’ve “read”.
This light be a little extreme, but you might be able to put repellent plants near where you park that will keep them from approaching as much as as supplement.
pfmusician
Pat
Pennsylvania
I’m considering getting some of that Honda branded rodent tape to wrap my engine wires before they start to snack on them. The damn stuff is EXPENSIVE! About $50 a roll!
my problem is a hickory tree in my front yard. Every year it drops thousands of nuts (I called them acorns but more correctly they are hickory nuts). It was never a problem in the past but for some reason this year it has been a disaster. That tree is coming down this summer. Hopefully that will solve most of the problems. All the anther trees are far away from my cars.
One other cars, I've had the luck with placing chicken wire screen (1/4" spacing) over the intake, which I bought at Home Depot. I also covered the trunk cabin air exits after finding a nest inside the trunk.
The screen wire is fine, so minimal affect on airflow. Also galvanized against corrosion.
On 11th gen Civics, I would sandwich the screen under the hood rubber seal, at the airbox entrance. I found hickory nuts stashed with the moth balls I once used, so moth balls proved useless and stinky.
I'm fortunate our cars now have secure garage space.
MoodySara
New England
This ^^.
I tried the oils. They don't work for deer, either (although deer don't get into the intake; they just eat everything.)
On my Ford F350, the chipmunks ate through the filter and broke the wire in the air flow sensor. It wouldn't run at all.
I used 1/2" screen and hose clamps to close off the intake. That worked.
Or, you could take my niece's approach. She got an air rifle and blows away any chipmunk she sees.
