P0087 - Low Fuel Rail Pressure - 2021 CTR - thoughts?
shivpatel99
New Jersey
2021 Honda Civic Type R
I’ve been gotten a P0087 code on my way back from work. I have 2021 CTR. Car started fine, and would run a bit, approx. 20 min. Then as I exit the ramp, engine started to stutter and turn off completely. I was able to pull over to the side of the road. I tried to restart the car, but it would turn over for like 5 sec, then stutters and turn off again. I let to sit over night and in the morning, I was able to bring it back home. My initial thought that it was a clogged filter or failing LPFP since recently there was a problem with clogged injectors 4 months ago. The injectors were replaced. I replaced the fuel filter and LPFP (DWC300), but when I turned the car over, but same issue. Car started and stutter and turned off.
any one have a guess to what’s happening? The only thing left is the HPFP by this point. Maybe an electrical problem, but not too sure.
Had a customer with a similar issue. We ended up doing a direct wire kit towards the pump, with new cannister and fuel pump and that solved the issue. Check the electrical feed to the pump.
