P0507 Code - Idle Control System RPM Higher Than Expected
arbies
arbies
Scott
Austin, TX
2023 BB Type-R
Unfortunately, no update. The car has been at the dealership (First Texas Honda) since the 13th, and they still weren't sure what was the throwing the codes as of 2 days ago. I'll be sure to post updates here once they (hopefully) figure it out.
mbaapk
Twin Cities
Pacifica
Could it be a fuel octane issue - too low or shitty gas?
Id have them drain the tank and refill with 93
02SilverSiHB
Annapolis, MD
2023 FL5
Just had this code pop up today and only mod I've done that might have triggered it is an intake...gruppeM. I've had the intake on for 3 weeks then allll of a sudden I get this lol.
Cleared the code and will do datalogs and see if my tuner can see anything. Love these kind of codes.
Edit:
Last night I got a chance to check over everything. One coupler (factory one) was slight angled wrong. I can't believe that was the cause, but, today...idle is perfect and no CELs. I'll keep an eye on it...but try checking simple stuff like that if you run into the issue again.
arbies
arbies
Scott
Austin, TX
2023 BB Type-R
Just got an update from the dealership, and @mbaapk was right! Turns out there was too much water in the gas. They suspect this was causing the latest codes, especially the cylinder 1 & 4 misfires. They're going to drain and re-fill.
arbies
arbies
Scott
Austin, TX
2023 BB Type-R
Edit:
Nice. If you get a chance, can you post a picture of that specific coupler?
Mimzie2763
Parker
North Carolina
1997 Toyota Supra Turbo 6MT, 2023 FL5
What gas station did you use?
arbies
arbies
Scott
Austin, TX
2023 BB Type-R
I wish I knew. Between all of our family members' cars and different people driving the Type R, it's hard to trace down by looking at past purchases.
mbaapk
Twin Cities
Pacifica
So good to hear it was something simple, what a relief!!!
CTR FL5
PJ
CA
Not losing boost or anything but it is annoying knowing when my pop/bang turns off due to this (pending) code. Also updated and reupload with fp current firmware.
What became of this? Did you find thr culprit/issue and how did you resolve it?
