High pitch squeal over 5000 RPM WOT
drj_fl5
Douglas
new jersey
fl5
Hey guys. Have this high pitch sound you might describe like a super charger whistle or even a tea kettle. Happens around 5000 RPM with WOT pulls only.
Current Build:
2025 civic type R
100% stock internal
Stock clutch, stock transmission
27WON Kuro+
27WON high flow catted down pipe
Eventuri intake
PRL inlet
PWR intercooler, PRL piping
27WON exhaust
Full race hpfp
Dw300c lpfp
Hondata 2000cc injectors
Hondata canflex
Hondata flashpro
Spoke with a few in the community who have heard same sound with similar builds. Anyone else dealing with this or know where it’s coming from? Is this normal with these builds/stock frame turbos?
Superhatch
Jacob
Wisconsin
Sounds like maybe air being pulled in or pushed out of a very small opening. Maybe some boost leak? I'd be curious not about the RPM but about the boost levels when you hear it.
drj_fl5
Douglas
new jersey
fl5
Hey appreciate the reply. The mechanic that did all my work also thought it might be a boost leak, possibly a loose charge pipe. Definitely going to check all connections. Interestingly enough I sent data logs to my tuner who said everything looked good. Another FL5 guy said he heard that noise during every WOT pull for 2 years and also thought he had a boost leak but came to the conclusion that the sound has something to do with these stock frame turbos. Idk it’s a little annoying so will continue to investigate before settling with it.
drj_fl5
Douglas
new jersey
fl5
I’ll make note of the boost level when it starts.
drj_fl5
Douglas
new jersey
fl5
Seems to start around psi
ModJPB
Jason
On the FL5, VTEC kicks in at about 5000RPM. Most likely related.
