P050A IDLE CODE.
HECTOFL5TYPER
Hector
2025 TYPE R
P050a- Cold start idle air controller performance problerm.
Got this code after I Installed Hondata 2000 injectors, Radium dual catch can CCV and PCV side. Any idea what could trigger this code? I do remember installing all the vacuum lines. Currently not at home. Will check everything tomorrow. Any ideas or things to look out for will help. Thanks.
Hopefully you've got this sorted by now, but 2 things come to mind:
1. If you didn't program the ECU for larger injectors, the engine should run too rich and likely beyond O2 sensor trim. At least that's the scenario in the port injected engines I'm familiar with.
2. Torn injector o-rings may result in result in compression and/or vacuum leak issues.
HECTOFL5TYPER
HECTOFL5TYPER
Hector
2025 TYPE R
Thank you sir ! It was first startup glitch. I cleared out the codes and didn't come back. Thanks for the help.
