PRL Motorsports 1.5T PNP Flex Fuel Kit
Status
Not open for further replies.
esqfenix
Jerry
Honda civic 2017 hatchback ex-l
I just recieved this. Are there any instructions available?
AREA
Chris
Houston, TX
95 hatch Drag car, K20Z3 00 Integra, 07 Civic SI sedan and 18 Civic SI coupe
crank024
John
Chicago Illinois
Honda Civic Si Sedan 2018
i just ordered yesterday i hope im gonna receive it soon. one more question so if i install that one what im gonna put pure e85 or im gonna mix with 93 sorry about that im new on flex fuel kit
PRL Motorsports
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
Thanks for inquiring about our flex fuel kit. You will need to mix a blend of pump gas and ethanol, running 30-40% ethanol is what most are doing to add extra power.
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
To get TSP's recommended 30-40% it would probably typically take near a 50/50% mixture at your pump. I would just put in 3 or 4 gallons of E85 and then top off with 93. That should bring you close. For the first time though you might put in a little less E85 to see what your Ktuner ethanol parameter reads. Note that pumps vary on ethanol content so this is just a starting recommendation. I am aynal so I use an android app in my phone to try to get an exact blend.
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
so straight E85 is bad or just a waste?? I'm going to be using ktuner base flex map
That is a good question! I don't know. The gas station that I go to changed the ethanol percentage from 60 percent to 77 percent. That caused me to have a tank of E45. My butt told me that the car wasn't running as strong as on when I was on E40. I just used up 3 gallons and topped off with 93 and the ethanol percentage dropped back into range. But, I don't fully trust my butt.
AREA
Chris
Houston, TX
Made my own how to video on this! Enjoy!
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
Congratulations! Another excellent video. Too late for me as I have already installed my TSP flex fuel kit. I am sure it will be a lot of help for many others.
One small caution I would like to add is that the taught cable to the engine might be an issue for some as the engine moves with acceleration and may overstress the cable if it is too tight. With your 27Won rmm I am sure it won't be a problem as your engine won't be moving much on acceleration.
Again, great job!
AREA
Chris
Houston, TX
AREA
Chris
Houston, TX
Yes. Just watched your downpipe/front pipe video too. Will be installing mine this week!! Can’t wait.
Awesome glad I could help!
Status
