PRL Motorsports Bolt-On Big Turbo Upgrade Kit
Status
Not open for further replies.
farqt
NE
18 si
the gen 1 gtx2860r disco potato just has a much higher choke point than the gt2860 (for the most part, it depends on the housing, chra bearing build, etc, but if you look at the garrett compressor maps that is what you'll see). the gen 2 gtx2860r is where you will big gains over a vanilla disco at the same same exhaust pressure.
i would be very surprised if they aren't testing on larger injectors and simulating factory fueling for package testing experiments and running ethanol blends on the larger injectors for peak power measurements. this is the same approach i am taking with my project car (ie, not the honda) and that most of the turbo builders i know use in testing (with a spare block for every car they're testing on)
AREA
Chris
Houston, TX
95 hatch Drag car, K20Z3 00 Integra, 07 Civic SI sedan and 18 Civic SI coupe
Didn't Eman just make 465 dynapak with this turbo kit and meth injection on Motec?
AREA
Chris
Houston, TX
davemarco
2019 Civic Type R (CBP), 2013 Audi TTRS
Waiting to see what turbo Eman chose!
GTX2867 Gen 2. Looking at the power curve that he posted, it honestly resembles a turbo 8th gen, but without the 8K RPM red line. Very low power on the low end (<100 hp by 3000 RPM), climbing to decent power in the mid-range, and crazy power on the high end. He also raised his redline to around 7K RPM.
That said, I have to wonder how fun it would be to drive in non-racing conditions, considering that the low end power has been completely gutted and the stock engine can't rev to the moon anymore.
360glitch
Moderator
I think that turbo is going to be more well suited for track use. I wonder which exhaust housing he is using. Probably the larger one?
farqt
NE
18 si
i think the 2867 is too big for this motor. if it had a head and internals that could spin up to 8k without destroying itself, you could take advantage of the upper end of the compressor map, but without the exhaust pressure to take advantage of the upper end of the curve, you're effectively tossing in a 2860 at higher cost and higher lag.
otoh if you have a bored out built motor and ported head, you could push enough power with the 2867 to retain drivability and twist the chassis in half at high rpm...
kshawn
Matthew
Maine
2017 Civic SI
Well the built motors are right on the horizon. So we'll find out soon enough
kshawn
Matthew
Maine
2017 Civic SI
@PRL Motorsports I think I saw somewhere you guys are switching to motec for a ECU. Are you running into limitations with the stock ECU?
farqt
NE
18 si
Torque tables and limited fueling probably. The honda ecu interpolates everything.
Also VE changes significantly with any changes to the internals, and standalones seem to be the way to go when VE changes on most modern cars that do extensive sensor reconstruction using baked in curves
davemarco
Got this update from customer service a couple weeks ago:
"We are currently working on packaging up clamps, silicone, hardware bags and whatnot as we speak. All components aside from coolant lines and downpipe castings are here in our location getting ready for packaging. With that being said, coolant lines and castings are scheduled to arrive towards the end of the month, which means we can begin welding up downpipes and wrapping up kits once received.
Early November is looking very promising for shipment ETA."
PRL Motorsports
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44624672_2192637361003452_213238181284282368_n_zpsldezd3jw
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44597665_309926996505113_1888746382773190656_n_zpscrgihihi
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44613815_304968566899193_1284622476260671488_n_zpsry6eobny
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44606574_259608121423700_744573941296660480_n_zpsizn4qddq
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44726416_313079712851865_456139562788323328_n_zpsoodjgm63
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44786427_178219003056671_6722029830088425472_n_zpsn2kasijw
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44628850_649276685466328_4727623923233980416_n_zps1ueka4gl
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44671233_2273798932903501_6864899408928964608_n_zpsqpiia6lf
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44808434_282587809252845_4468503297816264704_n_zpsqerjvaav
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44681555_164698411140693_7114052184051810304_n_zpsdmfytoox
11th Gen Honda Civic PRL Motorsports Bolt-On Big Turbo Upgrade Kit 44628833_279320019357664_3519681168851075072_n_zpsuznwglth
We apologize for the slow delays on the kit, it's been hard to find time to snag pics and set things up for you guys. Please don't worry though, we've been busy moving forward with packing up components and kits! :) As of now all components are here and in the final stages of packaging aside from downpipes. Upper and lower downpipe castings are scheduled to arrive shortly and will then need machined, fabricated and welded up to ship kits. Here's a sneak peak of what customers can expect to receive (minus downpipe).
A few key points to touch on for the community:
  • 4-ply silicone couplers rated for high temperatures with receiving grooves for seamless connections and ease of installation
  • Zinc coated coolant lines and oil feed fittings for OE finish
  • TRUE Ceramic coated intake crossover pipe assembly
  • 304 stainless heat shield
  • Stainless multi-layer gaskets
  • Stainless and Zinc coated hardware
  • TurboSmart Kompact Recirc BOV
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
We have tested quite a few different ethanol blends, mapping, the GT2860RS, GTX2867R GEN2 and now the GTX2860R GEN2. The engine is pretty much at max potential until we can get past the MAP sensor limitation and fueling limitations.
Eman has the GTX2867R GEN2 and small .64 A/R housing, the 67 is just that lazy on this small 1.5L motor. We feel that the 2860's are the optimal solution for street guys, but for Eman that is going to pushing the limit racing, the 67 makes sense. We feel that these cars truly need a camshaft upgrade to make the most of anything larger than a 2860.
We do have a CSS machined block and JE pistons here awaiting our rods to come back from Crower to assemble for backup. The rods are going to be the first weak point. We also have Crower valve springs, retainers and locks to install for safety, but the factory cams are already a limiting factor. We really need a camshaft solution to make the most out of upper RPMs.
We do have a MoTeC setup here for when we are ready to push things to their maximum potential, but we would like to retain the factory ECU and KTuner as long as possible to help keep developing and pushing this platform for the community. We understand that most customers will never choose to go MoTeC, so it doesn't make sense for us to abandon ship on a project that still has potential and appeals to the community.
farqt
NE
18 si
Thanks for the update!
Long term, it would be nice to know whether you can build the 1.5 longblock for big power or whether we should be looking for k20t motors out of crashed accords..
Status
