Removing shifter cable bushing upgrade
NUshek
2018 Civic Sedan EX-T 6MT
When I did it I couldn’t budge those C clips so just skipped that part.
I wondered if it was possible to install these bushings without removing the C clips (I saw one video where they did it without removing the clips). Good to know, thanks!
bri
OC, CA
2018 Civic Type R, 2010 G37S
It is possible, you just don't have a lot of maneuverability of the cable ends, so it's a little tighter fit to get your hands in. I ended up pushing them in with an adjustable angle head pipe-wrench pliers.
sdj544
Steve
Simi Valley
2017 Civic Si
I found the larger/far one was easy to do without removing the c-clip.
The smaller/closer one I tried to do the same but couldn’t get it back on with the new bushings. Fortunately it wasn’t that hard to remove just that one.
-S
ACUITY
Russell
Baton Rouge, LA
2017 Si
It is sometimes possible but not advisable. The small bushing does not like to go on at an angle and can get gouged doing so. Additionally, not disconnecting the cables from the bracket makes it easier to over-extend the swivel joint in the cable near the bracket which can cause permanent damage to the cable (if you cause the damage to the cable, you will notice that all even gears feel "mushy"). While damaging cables is rare, it is possible, and not removing those clips makes your odds worse.
~russ
bmaf55
Brian
2018 Civic SI sedan
Did you guys remove the battery or anything for that matter to get at these bushings?? It looks real tight in there.
Matthyahuw
Matthew
Valley of the Sun AZ
2018 Agean Blue Civic Si Sedan 2016 Omaha Orange Jeep Renegade Trailhawk
Yes, Acuity has remove the battery in the install instructions.
If you don't want to do that, follow Boomba's instructions for their trans adapters.
You'll be removing more things however. I preferred Acuity's way of doing it for both products.
bmaf55
Brian
2018 Civic SI sedan
Thanks. I think I’d rather just remove the battery.
