SiriMoto Short Shifter and Krispy Shift Kit for 11th Civics
procivic
Ventura, California
www.procivic.com
2022 Civic Si Sedan, Others
Attention all 11th Gen Civic manual trans owners, you're going to want to check out these two new products from SiriMoto we have!
Similar to their 10th Gen Civic offerings, SiriMoto now makes a Short Throw Shifter and a Krispy Shift kit for 2022+ 11th Gen manual transmission Civics. The SiriMoto short shifter is an adapter style design that installs onto the end of your factory shift lever. It results in a 25% decrease in shift "throw" on 11th Gens. Some of you may be wondering what exactly shift "throw" means, so I'll explain: Shift throw is simply the total distance you need to move your shift knob to switch gears, that's it! The 25% decrease applies to all gear changes too, not just 1st to 2nd. Having a shorter shift throw makes driving more enjoyable and your shifts faster as well.
Works on both with 1.5L turbo and 2.0L non-turbo 11th Gen Civic models.
Key Benefits:
  • 25% reduction in shift throw!
  • Optimal specs designed to adjust fore and aft travel.
  • Includes MIL-Spec thread-locker for permanent installations.
  • Knurled-end set-screws to prevent loosening, even when installing without thread-locker.
  • Covered by a 1 Year Limited Warranty.
  • CNC machined from high quality 301 stainless steel.
  • Can be ordered with an optional Ball-End replacement bushing, which is precision machined from acetal and replaces your factory bushing for a more solid shift feel.
Forum discounts ARE available. Simply PM me if interested.
The nice thing is that both these products are inexpensive and provide real benefits and extra enjoyment every time you drive your manual 11th Gen.
Link for product details with an animation, and to order: https://www.procivic.com/p/m/civic/sirimoto-short-throw-shifter.html
11th Gen Honda Civic SiriMoto Short Shifter and Krispy Shift Kit for 11th Civics 1659992084726
If you want an even better (more solid) shifter feel, try the SiriMoto Krispy Shift Kit. It's everything the SiriMoto Short Shifter is PLUS the optional Ball-End bushing AND the SiriMoto shifter base bushings. Here's the link to the Krispy Shift Kit: https://www.procivic.com/p/m/civic/sirimoto-krispy-shift-kit.html
11th Gen Honda Civic SiriMoto Short Shifter and Krispy Shift Kit for 11th Civics 1659992421682
