TSP Senkō Series LED Headlights for 22-26 Honda Civic - Preorder now!
11th Gen Honda Civic TSP Senkō Series LED Headlights for 22-26 Honda Civic - Preorder now! 1781899495119-78
Clear side marker option
11th Gen Honda Civic TSP Senkō Series LED Headlights for 22-26 Honda Civic - Preorder now! 1781899527016-f
Amber side marker option
11th Gen Honda Civic TSP Senkō Series LED Headlights for 22-26 Honda Civic - Preorder now! 1781899619865-a
11th Gen Honda Civic TSP Senkō Series LED Headlights for 22-26 Honda Civic - Preorder now! 1781899636847-y
https://www.twostepperformance.com/...ial-headlights-2022-honda-civic-integra-style
Pre-Order Now for the First Batch!
  • First batch expected to ship before September 30, 2026
  • Introductory pricing available until the first batch hits the TSP warehouse or until the first batch allocation sells out (quantities are limited!)
  • Standard TSP Order Cancellation Policy applies
Transform the Front End of Your Honda Civic
Give your 2022+ Honda Civic a complete frontal makeover with these full LED projector headlights, available exclusively from Two Step Performance. Styled after the aggressive, premium look of the 5th gen Acura Integra, these headlights deliver sharper output, a modern lighting signature, and a clean, factory-quality installation you won't find anywhere else.
5th Gen Integra Styling
Inspired by the sleek, high-end design of the 5th generation Integra, these headlights bring a more aggressive and refined aesthetic to the front of your Civic. The distinctive LED daytime running light signature instantly elevates your build and sets it apart from every other car in the lot.
Make a Bold First Impression
Every time you start your Civic, a dynamic start-up animation sweeps across the LEDs, giving your front end the same head-turning, high-end character you'd expect from a flagship vehicle.
Sequential LED Turn Signals
Featuring sequential turn signal technology, these headlights combine enhanced signaling clarity with a sleek, modern flow. High-intensity LEDs ensure other drivers can clearly see your directional changes, even in poor lighting conditions.
Plug & Play Installation
Installation is simple and fast. These headlights are designed for direct OEM replacement with a plug-and-play setup. No splicing or rewiring necessary.
Durable & Weather-Resistant Construction
Built to handle real-world conditions, these headlights feature a sealed, weather-resistant housing that protects internal components from rain, road debris, and moisture for long-lasting performance.
DOT & SAE Certified
Our amber side marker option is tested and approved by both the Department of Transportation (DOT) and Society of Automotive Engineers (SAE); these headlights meet all U.S. road safety standards and are 100% street legal. The clear side marker option is intended for off-road and show use only and is not DOT/SAE compliant for public roads. Be sure to check your local and state regulations before installing on a street-driven vehicle.
Warranty & Customer Support You Can Trust
Includes a 12-month warranty and responsive customer support. If you encounter any issues during use or installation, our team is here to assist you.
Package Includes:
  • Complete LED Headlight Set (Driver & Passenger Side)
  • All-LED construction – no extra bulbs required
Vehicle Compatibility:
✅ Fits: 2022, 2023, 2024, 2025, 2026 Honda Civic (all trims)
❌ Does not fit the Acura Integra; styling is inspired by the 5th gen Integra, designed exclusively for the 11th gen Civic.
