Tyre experts: Hankook Ventus RS4. Can you check my thinking ?
joshinthecity
Josh
Sydney Australia
2025 CTR. Championship White.
Hiya.
2025 Type R
I did a track day (night) here in Sydney recently, and pretty quickly found the limitations of the stock tyres.
On the up-side, they vaporised very evenly across the faces and were trashed both front and rear, showing the basic balance is good. It was a cool night in Sydney and I think I've just driven past the OEM rubber's design brief. I'll get another track day out of them though..
I'm looking to buy a replacement set in a 200 wear rating. and these RS4's are very well regarded and praised by others for (relatively) long life, which means I can try to run them all the time. (Car is not a daily). I don't want to buy a 2nd set of wheels (18's) if I can avoid it by trying this first.
I'm on stock suspension and I will be for some time as I have a driveway with awkward geometry.
https://www.hankooktire.com/au/en/tire/ventus/z232-z232.html
The nearest size the RS4 comes in to to stock is 275/35ZR19W XL
Stock tyre size is 265/30-19
I suspect these will fit-up and work just fine, but it seems prudent to check-in with the brains trust on this one before going ahead.
What say you tyre gurus?
Thanks.
Josh.
11th Gen Honda Civic Tyre experts:  Hankook Ventus RS4. Can you check my thinking ? 20260913_130936
11th Gen Honda Civic Tyre experts:  Hankook Ventus RS4. Can you check my thinking ? 260908_Green_0271 copy
11th Gen Honda Civic Tyre experts:  Hankook Ventus RS4. Can you check my thinking ? 20260913_130836
11th Gen Honda Civic Tyre experts:  Hankook Ventus RS4. Can you check my thinking ? Screenshot 2026-09-14 at 11.59.58 am
J_D
J
Montreal
Your stock tyres look brand new, almost no wear. What you are seeing is rubber from other cars that is stuck to your tyres. I am feeling that you are a beginner correct?
I would just run the factory tyres for a few more events has you build skills and confidence. Keep an eye out on hot pressure after a session. IIRC the PS4S likes 30-35 PSI on track. Others will chime in
For the RS4 get a second set of wheels, 18x9.5 5x120, and 265/35/18 tyres.
joshinthecity
joshinthecity
Josh
Sydney Australia
Thanks JD.
Yes, you are correct, the rubber on the tyre is mostly pick-up.
Novice (always learning) not beginner.
I want and need more grip. I feel on track the tyres are heating up well beyond what they were designed for (fast road driving) in a 15 min session. They are excellent road tyres in my opinion. With an Australian summer about to begin, (40 degree days) this will become much worse and untenable.
The RS4's have a very strong reputation here for holding up against very high temps.
Ideally, and eventually, 100% I'd run 2 sets of wheels / tyres, but in this case, I need to stay with the factory wheels; at least for now.
