Will Older Model Civic Fog Lights Fit 2022 Si?
Tron
1980 MGB, 2007 Mustang
I know I can order OEM fog lights for my U.S. 2022 Civic Si and install them. But there are cool (and cheaper) fog lights you can buy for older civics that look to be very similar to the 2022 fog lights. Will these fit? Does anyone have measurements for 2022 OEM fog lights? The Aliexpress listing has measurements I could compare against.
OEM Foglight part numbers:
FOGLIGHT LEFT FR. - 33950-T20-A01
FOGLIGHT RIGHT FR. - 33900-T20-A01
2013-2015 Civic Fog Lights:
https://www.aliexpress.com/item/4000402433103.html
turbomike
Honda Canda - West, the track, not in your DMs
23 FL5 CTR, 22 MDX-S, 20 FK8 CTR
No
Shankmeyster
AZ
23 Si
Every time they change the body style you are most likely not going to find any parts from the old body that will fit on the new one.
Bunhyung
Benjamin
Maine, USA.
'22 CBP ST
In regards to fog lights, Japanese manufacturers mostly adhere to three different templates in regards to the mounting brackets. Type A, B, or C.
Honda's use Type A. So almost any Fog light kit that adheres to the standards will fit. Most high quality makers, ie: Morimoto, Diode Dynamics etc... all would work I would think. The only variable may be the size of the actual opening in the bumper cover.
From the pictures I have seen of the 22 Civic bumper cover, the mounting hole pattern is standard.
