WOT Performance Dual Oil Cooler Kit
siwelnosaj
Jason
Reno, NV
Type R
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986687510
I’m very proud to share the official release of my WOT Performance Dual Oil Cooler Kit for the FL5 and DE5!
This has been a project a little over a year in the making. A ton of effort has been put into this project to ensure that #1 it is the best performing kit available, and #2 that it does so without you noticing.
The goal all along has been to create an uncompromised solution using the best components. Unrivaled in performance and form.
Cutting the bumper or placing coolers in front of the radiator were easy solutions, but not at all optimal ones. I aimed for a kit that is stealth and doesn’t require cutting the front bumper. I also did not want a cooler to sit in front of the radiator and block airflow, or worse yet, feed it superheated air. I wanted an uncompromised solution.
As you can see in the pictures, my kit replaces the OEM brake ducts with our own custom designed dual ducting system. These maintain feeding air to the brakes per the OEM design, and additionally, they provide the two oil coolers with plenty of focused fresh air.
An obvious question is, “Does this cause issues for the brakes?” Delicate care was taken in the design process to address this, but we wouldn’t really know unless we tried it out. So, track testing was done on three separate track days ranging in ambient temps from 62°F up to 101°F. Beyond my own expectations no delta was observed in brake caliper temps when comparing the WOT ducting vs the OEM ducting! Brake temps and performance were identical when compared to sessions where only the OEM brake ducts were used. This was incredible! My rationale for this result is that the OEM design is an indirect system that is not completely efficient to begin with.
As can be seen in the provided graphs, the oil cooler kit performed amazingly. Oil temps were reduced by 35°F and coolant temps by 30°F! Massive game changing improvements. Oil temps were collected using the physical sensor I have installed in the oil pan, which is measuring temps post engine and pre oil coolers. Had I measured post oil coolers temps would be even lower! The oil used in testing was Pennzoil Ultra Platinum 5w-30. Additionally, the kit adds approximately 1.6 quarts of oil to the system which helps to share the thermal load.
Oil pressure with the PWR single pass oil coolers was observed to only show a drop of 4-5 psi when at a similar temp vs with no coolers. In an absolute sense though the psi was the same at the end of the 20 minute sessions given that the oil did not get nearly as hot with the coolers installed vs without; pressure was more easily maintained with the lower oil temperature.
In summary the WOT Dual Oil Cooler Kit:
- Has been shown to reduce oil and coolant temps by 35°F and 30°F, respectively
- Uses top of the line components: PWR cores, Raceflux lines, and HEL thermostatic sandwich plate
- 3D printed ducts, CAD modeling via Casale Design LLC who also designed the Spoon Thill 24h bumper vents and is an aerospace engineer by trade
- Retains OEM brake function, No brake cooling issues
- Requires no cutting at all of the bumper
- Does not obstruct airflow to the radiator
- Uses exit vents in the fender liner, angled outboard to evacuate hot air out (no issues with front end grip or unusual tire wear has been observed)
- Maintains OEM wiper fluid function via a relocation reservoir that reuses the OEM honda motor, plug ‘n play
- Maintains easy daily driving oil warm up via 180°F thermostat in the sandwich plate
- Uses 10an Raceflux lines which have a lifetime warranty against leaks with the fittings
- Minimal drop in oil pressure vs OEM
All kits will be built to order with an estimated 4 week turnaround time. Cost is $2100 USD shipped within the USA. $1800 for the DE5 as it does not require the ducting, they can use their front bumper vents. Willing to ship internationally as well. No other vendors will offer this kit.
To order, contact me directly on here or
facebook: Jason Lewis
IG: @wot__performance
email: [email protected]
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986677124
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986680645
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986684036
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986705823
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986690875
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986693853
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986696382
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986702592
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986699861
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986709656
11th Gen Honda Civic WOT Performance Dual Oil Cooler Kit FB_IMG_1748986712218
Brittania
Brian
North Carolina
2024 FL5
You guys are crushing it and doing it the right way!! Did you paint the PWR intercooler yourself or is there an option to purchase already painted?
siwelnosaj
siwelnosaj
Jason
Reno, NV
Type R
Thank you! I had it powder coated by PWR. I am an authorized dealer for PWR as well, so if you want one for yourself let me know.
siwelnosaj
siwelnosaj
Jason
Reno, NV
Type R
Seriously impressive! Hope you'll keep making these in the year it'll take me to get out of warranty ?
Thank you and yeah I plan to keep making it as long as people keep wanting it. Let me know when you're ready.
siwelnosaj
siwelnosaj
Jason
Reno, NV
Type R
What kind of drops in temps would be expected with your under tray cooling plate.
Are you asking with just the plate? By itself customers have reported back to me anything from 10° to as much as a 30° F reduction in coolant temps. There's really just a lot of variables at play that can determine how much it helps: track specific demands, car power level, ambient temps, other cooling mods in place, and driver pace.
Ic@ns33urhrt
Southeast
A car
Thanks. Will have to think on it.
Simply awesome and thank you so much for the solutions that you have tested, shared details, and are offering to the community. I already have your cooling plate installed while still running the OEM radiator and parallel coolant system.
Adding your dual oil cooler kit has been on my radar to consider to start offloading the parallel system from relying solely on the OEM radiator for cooling everything. That said and as you shared, the dual oil cooler kit paired with the cooling plate is showing impressive results.
Coolant temp numbers look solid over various hard laps. For those that have installed your cooling plate, would you recommend the triple pass radiator or dual oil cooler kit as the next logical upgrade item to consider?
siwelnosaj
siwelnosaj
Jason
Reno, NV
Type R
That's a good question. I think the next logical step is actually the dual oil cooler kit because I believe oil temps are actually the larger issue with this platform. Ultimately I do believe the radiator with transmission cooler is an important piece of the overall puzzle, but in the scenario you're talking about, I would go with the dual oil cooler kit first.
Ic@ns33urhrt
Southeast
A car
Have you done any testing with just one oil cooler and the cooling plate? Or do you have any educated guess on what temps would look like? Just looking at it from a cost saving perspective. You may not sell it with just a single cooler. Thanks.
siwelnosaj
siwelnosaj
Jason
Reno, NV
Type R
Fair question. I have not done any testing with just one oil cooler and the cooling plate.
From the beginning I felt we needed to go with 2 coolers, and really that comes from my experience with the FK8. I was one of the few, and maybe one of the first, to be running a dual oil cooler set up on the FK8.
There were a ton of individuals who were using a single cooler and it simply wasn't getting the job done for them. I went with 2 and I've never had the problems they had.
I was also running my secondary radiator set up for most of my time with the FK8, but before I had it, it was just the 2 oil coolers, and I was having good results.
Lastly, recently when I did my test in 100+ ambient, that was with the dual set up, my WOT spec triple pass, and the cooling plate, and we were right on the edge. My goal all along was to make the car viable up to 100° and I'm confident with 1 oil cooler we would not have made it. I feel like it's vital to have the 2.
