2023 Civic Sport Hatch compatible parts
jac.campbell2492
Jacob
Flagstaff
2023 Honda Civic Sport Hatchback, 6MT, 2.0L 4cyl NA
Hello all! I recently found a low miles honda civic sport hatch with a 6mt and the 2.0 K20C2. So far I am loving the platform, its definitely not the fastest thing ive driven, but plenty of fun for now. I was wondering if anyone with the hatchback has had any luck fitting FL5 type R parts/body panels to the civic sports. I figured the chassis is pretty similar, looking forward to hearing more!
ModJPB
Jason
Oh cheese and crackers Batman! It would be an all or nothing swap. Every body part, including the hood, would have to be swapped since one piece at time would interfere with each other, except for the spoiler. You would also need the under bumper support bar and mounts and wheel spacers for the wheels since the type R is noticeably wider wheelbase. By the time you're done, the cost of it all you could have bought an actual Type R.
I'd looked into it when I had a sport as well and @ModJPB is right on the money. I think only the front doors and hatch are shared between the two, and maybe some parts of the chassis that you wouldn't really even want to swap out. Not even the front windshield is the same. The interior is a different story though.
HKSpeed
Orange County, CA
FL2 6MT
Examples I seen of stock FL5 parts on a FL1/2:
  • wheels with 5x114.3 to 5x120 adapters
  • rear spoiler
  • rear motor mount
  • matte black dash trim
  • hood
A guy in Florida put FK8 seats his FL2. Reprogramming the electronics was needed to eliminate dashboard warning lights.
  • rear spoiler
  • rear motor mount
  • hood
I thought the hood wasn't compatible? I remember someone posting that the cf hood from a ST didn't fit on the CTR
HKSpeed
Orange County, CA
FL2 6MT
Maybe the examples I saw were aftermarket 🤷 I assumed they were stock FL5 because they were paint matched.
Here's one example of a few I saw online:
Yeah someone mentioned it on that post as well but there's gaps and the hood doesn't flow with the fenders since CTR fenders are wider
ModJPB
Jason
Sort of. It'll work, but it doesn't look good. The FL5 hood front corners are slightly shorter and the hood latch is longer. It will "fit" but the latch needs to be repositioned and fender panels adjusted, even after all that things don't line up great..
jac.campbell2492
jac.campbell2492
Jacob
Flagstaff
From what Ive seen the type R wheels have different bolt patterns as well 5x 120 i believe.
jac.campbell2492
jac.campbell2492
Jacob
Flagstaff
Does anyone know if getting the brakes swapped on is doable?
ModJPB
Jason
No, from a Type R or S
Yes, from an Si or Integra base/aspec
Type R bolt pattern is different so the rotors won't go on. You would literally have to swap the whole suspension system not just the knuckles as the arms are different to.
Si /Integra brakes are an easy swap and are a noticeable improvement. One of my favorite upgrades since the civic base model brakes are scary weak.
To do this you will need to bend the heat guards back to accomodate the larger rotors. Minimum you'll need from an Si or Integra are the following...
  1. All 4 rotors
  2. Front pads only (rears are same size)
  3. Front calipers with bracket and recommend with hoses.
  4. Rear caliper brackets (calipers are same) and recommend with hoses.
