11th Gen Hood Gap?
francont89
Francisco
Toronto
2018 Civic SE
Hi all,
Have you all noticed there is a weird gap happening on the hood of the 11th gen sedans that is not uniform? See picture attached
The hood gap is different in the middle than on the sides. Wondering if this is an alignment issue or is actually designed like this.
I am looking forward to real world pictures of the hatchback to see if the same happens there.
11th Gen Honda Civic 11th Gen Hood Gap? 65797659-eddf-4494-b99f-7b71062f8f74
11th Gen Honda Civic 11th Gen Hood Gap? 65797659-edd2f-4494-b99f-7b71062f8f74
RobbJK
Robb
Columbus, OH
2019 Honda Civic EX Coupe
I have noticed that. And it seems to be evident on even some of the show cars from the reveals. It almost looks like the latch that holds the hood down is too tight/small and is bending the hood downward slightly. It seems only noticeable from certain angles but is none the less a bit annoying.
francont89
Francisco
Toronto
2018 Civic SE
Ok, so I am not crazy then. Agreed, it definitely should be an easy fix, hopefully production catches with this detail soon and can improve it.
RobbJK
Robb
Columbus, OH
Ok, so I am not crazy then. Agreed, it definitely should be an easy fix, hopefully production catches with this detail soon and can improved it.
No, definitely not crazy, I've seen others make mention of the uneven hood gap on other threads and forums. At this point, with the cars developed and in production, I'm assuming this is intentional for some reason (possibly having to do with the fact that the hood is aluminum now) as opposed to just an error they didn't catch, a bit too obvious for that.
silverrascal
2019 Honda Civic EX hatchback
Hopefully, this issue is an easy fix like merely adjusting the rubber stops so the hood sits more flush.
hikaru
Shawn
Marietta
Yes, this is one of the worst things I feel about the car when I first saw it. The hatchback appears in the Japanese market intro has a better fitment.
The TLX has a better fitment too.
https://www.honda.co.jp/CIVIC/new/
11th Gen Honda Civic 11th Gen Hood Gap? 1625551377645
hondacm450e
Chicago
2016 Civic 1.5L Turbo Touring
Yea I also have this strange hood gap and it looks terrible in sonic grey pearl.
Shankmeyster
AZ
23 Si
Better take it into the dealer and point it out. The more people point out defects the sooner you get a recall.
