2023+ (FL5) Type R bolt pattern
Tickle
Interesting...
I was interest in the RS055RR..
System Motorsports
Thomson
Thomson
Hayward
Black (CBP) FK8 Civic Type R,
Confirmed TE37SL 18x9.5 +45 5x120 (Concave Face) will fit new FL5 11th Gen Civic Type R! We have these ready for those getting their Late Fall deliveries!
System Motorsports
Thomson
Thomson
Hayward
any idea what the stock wheel offset is?
Stock wheel offset is 19x9.5 +60. 18x9.5 +45 will be the perfect spec for this car for those who want to fit better rubber and reduce unsprung weight in the aftermarket realm.
System Motorsports
Thomson
Thomson
Hayward
How's 18x10 +41 looking? My wheel math is rusty
It will work but you might lack inner clearance - Our TE37SL in 18x9.5 +45 5x120 will have about ~2mm more inner clearance with the inner liner/firewall and at full lock, and it will be flush. The 18x10 +41 will be about ~10mm more outwards poke than what you see below.
This is TE37 18x9.5 +45 5x120 with a 265/35/18 tire.
11th Gen Honda Civic 2023+ (FL5) Type R bolt pattern 1662057139886
MuckyBarnes
Vancouver B.C.
That should be similar to the FK8, right? I was at -2.5 camber all around with cut rear fenders.
System Motorsports
Thomson
Thomson
Hayward
Yes and no - The FK8 previous gen could fit 18x10 +41 (effectively same outward clearance as 18x9.5 +~35) which required fender trimming. It is very likely the new FL5 11th Gen CTR will not require any fender work for 18x9.5 +45 squared setup. The last thing people would like to do is to cut up a new FL5, so if one would like to fit 18x10 or even 18x9.5 +38, they would likely have to atleast massage the rear and front fenders on this new gen. The good news is that it looks like there isn't a "fake" flare on the new CTR like the FK8 Gen. We would say that only the 18x9.5 +~45 sizes would prove to be a bolt-on affair. It's a bit more conservative in sizing compared to the FK8 CTR from what we are seeing.
MuckyBarnes
Vancouver B.C.
Oof, that's too bad. Thanks for the detailed response though, much appreciated. I guess I'll hold onto my OGs for a while and see if anyone tries to fit 18x10, but it looks like I'll need some new wheels at some point.
System Motorsports
Thomson
Thomson
Hayward
HODL! But yes, it looks like 18x9.5 +45 might be the limit on OE suspension, any lower of an offset will not only increase the chance of rubbing at full compression, it is likely going to induce torque steer which the old FK8 CTR chassis experienced quite a bit with lower offsets.
