TchnoZ33
Zaid
Indiana
You definitely own your own shop? Lol. This is pretty cool. I’m jealous ?. Also, what are all the red strips around the outside of the car? Why did you end up taking apart all of the inside? Lastly, are you in Chicago ?.
kin0kin
kin0kin
Kean
Kuala Lumpur, Malaysia
Honda Civic Type-R FL5
Actually custom rims isn’t anything new but the forging process is not exactly the same as with say - Rays. The block is still compressed to over 10-12k tonne before being shaved to the shape you want. You can have it in any design and brake clearance you want.
Those red lines are masking tape. Car is in my friend’s shop doing ppf. I had to strip off the interior to get the wires to route properly. The whole center console also needed to come out to access the shifter. I still need to get wiring and piping done for the air cups. Which they still do not have stock for the size I needed. :(
Will be stripping the engine bay soon. I’m from out of the states tho.
kin0kin
kin0kin
Kean
Recaro Podiums
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build ac27605f-a9c5-480e-be7d-55979d49656
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 2cfac8bd-91f7-4593-b977-5f05525d6882
Podiums arrived. I had in mind that I ordered red alcantara but received them in black. Probably have to order some red pads later on.
I am well aware that these seats have driver and passenger shells where it’s determined by the FIA stickers location, I was still shipped with two driver shells but with separate driver and passenger paddings. You will notice that the recaro emblem on the shoulder pads are driver and passenger specific. However the FIA stickers are both on the left of the seats. This might trigger some ocd peeps considering the price of these seats aren’t exactly cheap.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4706
Finally gotten around doing the chairs. Two parts need to be transferred, belt buckle, and weight sensor.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4705
Getting the buckle out is rather self explanatory. Trace the wire and unclip the cable holders from the seat and remove the buckle.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4712
the weight sensor is held with multiple clips. I first dislodged the upper clips. Then lift the lower left clip and slide the metal retainer upwards to dislodge the left side. Following the right side.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4714
Once dislodged it will be in between the seat and the bottom frame. Depress the foam in then slide the sensor out from the right. You’d need some helping hands.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4725
Recaro actually made a hole to route the harness under the chair.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4726
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4728
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4732
the clips on the sides protrude too much. I managed to bend and snap off the two tiny hooks but the bigger piece needed to be cut off. Now it’s one flat piece.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4734
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4733
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4735
There are a few clips that still protrude out from the button cover so I added some foam tape to level it out. Then I applied VHB double sided tape to affix the sensor to the chair base.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4736
The sensor may seem thick but it cannot be felt when sitting on it.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4720
Taped the wire loom to prevent rattles.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4721
Here’s how I routed the buckle’s wire.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4737
And this is the weight sensor. What’s funny is that after all that, I realized that I could have just taped the sensor under the chair and never have to deal with the seal belt reminder and error code. Also for the price of this chair I’d thought that Recaro would provide the air bag canceller.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4729
One down. Another one to go tomorrow.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4730
For slider, base, bracket I’m using the PCi kit. It won’t go any lower or higher than this. I probably have to fine tune the height with washers.
Damn, beautiful seats.
I imagine you save around 20lbs each side without the sliders.
kin0kin
kin0kin
Kean
Rattle Fix #2 - Headunit/Dashboard
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3648
there’s some serious rattle around here. Gonna have to whip out the foam and felt tapes to tackle this.
Update: I’ve eliminated the rattle ?
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3692
Remove the four screws/bolts holding the Headunit. Undo the two connectors behind the Headunit and lift the Headunit up vertically. It’s held by three plastic clips.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3673
Next remove this module. It’s held by two screws. You don’t want to drop them.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3682
Slide some foam in between the AC duct and the dashboard frame. You can get foams from upholstery shop. Ignore the masking tape. I used them to hold down the clips when I was checking for rattles.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3685
Sandwich a foam under the module that was remove earlier then reinstall it.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3686
fold another piece of foam in half and shove it into the cavity between the module and the upper dashboard with a trim removal tool.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3689
here’s how it looks like after you are done padding the parts. Ignore the microfiber sponge I just left it in there to troubleshoot possible rattles from the harness.
Close the speaker cover and you are done. Actually after closing the cover I noticed that the cover is in contact with the back of the head unit. You might want to pad the contact points as well. For the time being I’m not hearing anymore rattles so I won’t be opening it again to do this step
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3678
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3677
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3679
here’s how inside of the dashboard looks like. There are a few felt taped contact points where the module attaches to the dashboard.
kin0kin
kin0kin
Kean
Stripping the Engine Bay
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3879
The bumper came off easily without needing to pry any clips as per some videos.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3866
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3872
drained the coolant and oil
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3881
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3908
Out the plastic, in the sealed single piece tank!
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3889
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3891
replaced the thermostat with a 68c one.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3910
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3913
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3916
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3926
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3927
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3929
Removed the mhi turbo and swapped it to 27Won Kuro (non plus). Heat is serious issue here, wrapped em up with some PTP Turbo blanket. Fitting is nice on these blankets but some wire splinters sure did some damage.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3932
PRL titanium inlet next
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3935
A very familiar engine bay. DEI gold tapes otw.
kin0kin
kin0kin
Kean
RMM in today
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3979
Heard good things about PRL RMM. If it ain’t sufficient I’d try the stiffer ones from Hasport.
Battle Bee Oil Cooler
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3980
oil cooler is quite a pain to install. Routing the piping is troublesome. Battlebee stuff is very well made imho. Shame that it isn’t widely available in NA yet.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4041
Will have this secured tomorrow. This bracket is interfering with my trans cooler that’s sitting on the other side so it’s gotta be cut off.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4119
The cooler came with O Rings to aid in flexibility but it lifted the whole setup a fraction too high.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4120
I’ve decided to remove the O rings and epoxy down the rad to the bracket for extra reinforcement and to prevent possible rattles.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4115
The trans cooler sits on the adjacent side.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4117
Cut off the bracket a little for it to slide into the same mounting holes as the oil cooler. I still have to adjust/fabricate the remaining brackets to get this mounted.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4166
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4167
One of the tubings was too long so I had to trim it off a little. It’s a piece of a cake getting the compression an fitting on if you had a clean cut. Otherwise get ready to bleed.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4168
Looping in the hose before re-terminating it.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4169
Managed to fit everything in without touching anything.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4171
It gets pretty close to the belt but I’ve zip tied down the hoses up top. They ain’t going anywhere.
In case anybody is thinking that this will likely kill the airflow to my PWR Rad. Well without a doubt it’s going to block some airflow. However the oil cooler wouldn’t active until the oil hits over 90+C. I might change to a higher temp thermostat so that it only opens up on over 100C. The Trans cooler probably isn’t going to pass on too much heat either. Due to the planning of this setup I went with the street version of this radiator. If it was the track version it’s probably going to heat soak on normal drive.
LCA Bushings and Anti-Lift Kit
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4016
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4019
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4020
The LCA is really difficult to get off so we dropped the whole cross member
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4023
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4025
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4026
Ever heard that if you went to a Chinese restaurant and if it’s too clean it’s probably no good. Could say the same about a machine shop ?
Pumped the LCA bushings out. Goodness the Powerflex 90a bushings are really stiff. The LCA is almost like a single piece now.
XDI HPFP + ID-F750
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4046
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4047
tomorrow I will machine out a bracket to mount my OCC, ID-F750, and the AEM Solenoid
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build ee29c1b4-6c95-4dda-98a7-fc49be28e95c
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4088
I masked off the whole firewall mounting holes. I’ll be making a mockup plate on an acrylic panel and see what are some of the best places to get everything mounted securely.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4163
Laser cut out an acrylic panel to mock up mounting location.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4123
If you run pracworks intake manifold you can’t put the id-f750 on the left of the fuel line exit. I’m most likely putting it on the right and the reason being there’s simply not enough room behind the manifold. Engine vibration will likely hit and damage the filter.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4121
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4122
Converted to AN6 fitting.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4231
Mocked up with acrylic on where the filter will be mounted.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build ID750F
Drawn out the plate, still got to print the mockup again to test fit this.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4360
Final measurement of the bracket is done. Pending CNC next two days.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4496
bracket is done and fits perfectly
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4508
The oem bracket for the fuel line isn’t needed. But I might modify it further to fit the bracket.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4509
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 86F5C2E3-0D7C-4C2F-87D3-D48FF0B5B3F2
The BattleBee trans cooler isn’t a direct fit so I had to draw out another bracket to flip it to the other side and extend it a little to mount the trans cooler.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 538121EB-604F-4C59-B7F0-BBA72A64A5AB
The ID-F750 has AN10 threads. Make sure to grab a pair of AN10 to AN6 adapters.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4389
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4387
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4390
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4391
I’ve modified and cut out all that I needed. My machinist about seeing the material told me that the OG brackets were actually aluminum. I’ve cut them out in 5mm mold steel. It was really heavy and I decided to re do them on aluminum. The plates will be done tomorrow and I’ll send them to get powder coated.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4361
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 077EF85C-E84C-4F50-8006-2052E4941BEE
If anything I really enjoy drawing 3D models :)
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4498
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4497
Vacuum Hose
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4423
It’s really sad that I couldn’t find proper vacuum hoses here where I live. I ended up ordering some gates 11/32 vacuum hose to reroute my brake boost hose and intake manifold hose. I’m not convinced by the included hoses from Praworks.
kin0kin
kin0kin
Kean
Water Injection
After much consideration I decided to use the AEM kit to just do water injection. I’ll tap into the washer reservoir instead of hooking up a tank in the rear.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4226
My intention is to mount the pump on the subframe front brace. Which is nothing more than a filmy sheet metal. I have ordered the cusco brace and will weld a mounting plate onto the brace later on.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4228
The hose is routed to the engine bay following the rad harness.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4229
Fluid Going In
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4533
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4532
Full flushed with PWR Rad, PRL expanded coolant tank, consumed 2 big bottles of VP Racing Stay Frosty.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4540
6 Liters of Motul 300V went in
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4541
Transmission with my Battlebee Transcooler consumed about 3 liters of Motul Gear 300 FF-LSD.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4557
The oil cooler came with two npt ports that I forgot to wrap and seal with teflon tape. Engine oil was leaking out from here unfortunately.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 2D0F6411-0465-4BD9-8AF6-E16BE0063884
nodnarb901
Brandon
Olive Branch, MS
I wanted to say thank you for posting this. I’ve been hunting down this same buzzing/rattle for months. Repeated your steps and fixed it! Thank you.
kin0kin
kin0kin
Kean
The belt height adjuster rattle is also real. I’ll tackle that next when I reassemble the interior.
Glad to have helped!
kin0kin
kin0kin
Kean
Time Skip
Took a long break from updating the build as the car went into cold storage. Below is the current setup.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4741
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4743
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4742
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4744
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build ec42ef22-43b3-494a-aa8f-4989e0340ee0
Many thanks to Derek @ IMWTuned for the remote dyno tune. The kuro delivers 437 whp on Ron 100, and 487 whp on e30. The car pulls very naturally now even on 4th.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4699
The car had some Ron97 (93 Oct) so we had to rig up the pump to drain out all the fuel.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4700
The shop bypassed the lpfp on the spot to get the pump going.
We tossed in some VP c85 since that’s what we had on hand.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4707
Rear preload & Height
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3914
I had my car corner weighted and supposedly aligned and gotten everything dialed in by a race shop. However I found out that my rear was extremely stiff and bouncy. My ARB also had quite a bit of uneven preload that was twisting the rear. So I had to get my own hands dirty today.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4672
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4678
I released all the unnecessary preload, shortened the casing, and removed all the preload from the ARB. Having less preload and more travel I’ve been able to run the damper at full stiff while actually being a lot more compliant than before. Everything is still within HKS’ no rub threshold. The rear springs had been replaced with 18kg swifts.
