27WON CAI
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
great! So that slit would be where it pulls air from the hood area? That shouldn’t be hot air if you are moving right?
thanks for answering all of my questions!
it looks like you addressed any and all issues reported in the early stages of this being released. I look forward to buying this intake.
it pulls from both the top and the snorkle on the bottom. mostly the bottom, think of the slit on top like back-up. Air moving over a surface will always be cooler.
jacobegg
Jacob
Oklahoma
2016 Honda Civic Touring
Looking to switch my Injen Sri to this 27won cai. What tunes do you guys use for it? I saw Hondata doesn’t have a pre loaded tune for it
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
Any of the +3,+6, or +9 base calibrations will work as our MAF was designed with the OEM fitment in mind.
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
That’s great! I got a little sad when I saw there wasn’t a dedicated tune for your intake. Glad it’ll work though!
Any questions don't hesitate to give the team a call.
PEPSIFLAME
Dallas, TX
2020 Honda Civic EX Hatchback
I just stumbled upon 27Won from searching for answers on if a CAI or SRI would be better for my 2020 Civic EX hatch. After reading this entire thread, 27Won's intake is my choice. Vincent seems like a pretty chill dude and has actively made efforts to improve the product, based on the community feedback. In April, when I get my bonus, I'm thinking of picking up the intake, as well as, the drop-in turbo. I'll be running stock tune for the time being though.
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
P51
Eric
Southern Calif.
2017 Civic Hatchback LX
I recently installed this intake on a CVT model. Following the instructions at https://store.27won.com/support/instructions/L15_6_305_10_installation_instructions.pdf was difficult due to the lower duct rubbing the CVT warmer. I went off the script a little bit and found some things that made it far easier.
1. On Step 12, I also removed the bracket that is below the ECU. It is MUCH easier to slip in the airbox while this is out of the way. Then I put it back in, from underneath the car, after Step 24.
2. I used different rubber isolator mounts. McMaster Carr Part number 9241K44 has a threaded stud on one side and a female threaded hole on the opposite side. Thread the stud into the frame and there is less in your way while you wiggle the airbox in. Then do final positioning and fasten using a regular hex head machine screw.
3. Instead of button head screws on Step 18, I used hex head. Not a big deal, but if you ever wanted to turn those fasteners with the airbox in place, it would be easier using a regular wrench on a hex head (less offset than an allen key/allen socket).
11th Gen Honda Civic 27WON CAI Screen Shot 2019-12-04 at 9.29.56 PM
11th Gen Honda Civic 27WON CAI rubber-vibration-isolator-mounts.jpg_350x350
PEPSIFLAME
Dallas, TX
Does anyone have audio or video of how this thing sounds? I like the design being a hybrid SRI/CAI, but wondering if it muffles the spooling sound.
jacobegg
Jacob
Oklahoma
Now that I don’t have to worry about Christmas presents I think I’m ready to treat myself to this intake. I have a friend who says never get a CAI no matter what. Can’t risk it sucking up water. I know this is the safe version of a CAI but should I still be worried about the risk of hydro locking? We’ll get some small flash floods every now and then where I live and want to play it safe.
Thanks!
xjoshuax89
Josh
Maryland
'11 CR-V SE, '16 Civic EX, '17 Civic HB ST
Thanks!
Only chance of hydrolocking this would be if you drive through like 3 feet of water and at that point it doesn't matter what intake you have. Even a stock intake would flood at that point.
jacobegg
Jacob
Oklahoma
Well that’s a relief. Thanks!
teg09
2018 civic sport touring manual
Anyone have issues with the 3mm bolts not fully seating in the airbox? I’m trying but I feel they stop short or thread snapped
Myx
Delaware
2018 Honda Civic EX (Hatchback/CVT)
Thanks!
If you want to play it safe, do not get a CAI. No sense causing yourself any unnecessary worries if you happen to go through some water, water that you'd be confident going through if you had a stock intake. It ain't worth it man.
