CTR
WA
strixauto.com
2023 Civic Type R, 2020 GX460
I've been a longtime member of this forum and have started developing some products for the FL5 and other vehicles under the brand @STRIX Auto. I have a few things in the works but the first product is a replacement hardware kit for the popular Project Aero front lip.
I'm a huge fan of this lip but like many others I struggled to install it with the provided hardware. Stacking a washer and a Nyloc nut between the bumper skin was nearly impossible and after cross-threading two of the fasteners I knew there had to be a better way. I was also not satisfied with the zinc plated hardware which can rust in automotive applications.
This FL5 Project Aero hardware kit makes installation easy and more secure using specialized fasteners. You DO NOT need to remove your front bumper to install the lip using this kit. This eliminates any sagging or shifting of the lip using their included hardware.
Also available for FK8 here.
The fastener material is stainless steel compared to the included zinc plated steel.
11th Gen Honda Civic Project Aero FL5 Front Lip Upgraded Hardware Kit PA_Hardware_FL5_Main_1
Includes:
2x M6 x 40mm Black Bolts, Washers, and Nyloc Nuts
8x M6 x 30mm Black Bolts + Washers and Nyloc Nuts
6x M6 Low Profile Bumper Nuts (Street Mounting)
6x Washers and Nyloc Nuts (Track Mounting)
1x Low Profile Wrench
1x Loctite Single Use Pack (243 Blue)
12/10/25 Update: Hardware was changed to black stainless bolts (coated per military spec MIL-DTL-13924) for a clean stealth appearance. Kit now includes extra nuts/washers for optional Track Mounting (through the entire inner bumper structure) to match PA version 2.0 instructions. Black color will fade slightly to matte black/gunmetal color when exposed to the elements.
11th Gen Honda Civic Project Aero FL5 Front Lip Upgraded Hardware Kit PA_Full_Hardware_Black
11th Gen Honda Civic Project Aero FL5 Front Lip Upgraded Hardware Kit LP_Wrench_Black_2
Note: We are not affiliated with Project Aero but do recommend their FL5 front lip splitter. The fitment, style, and quality is good. Although their lip comes unpainted, the lip shown in photos has been painted factory Berlina Black.
You can buy the upgraded FL5 hardware kit here:
https://strixauto.com/products/fl5-civic-type-r-project-aero-front-lip-hardware-kit
FK8 kit here:
https://strixauto.com/products/fk8-civic-type-r-project-aero-front-lip-hardware-kit
LogicalCC
Chris
Wow. I just got my Project Aero front lip today. How quickly can you ship out?
CTR
CTR
WA
strixauto.com
I can usually ship the next business day. So if you place your order today it will ship out tomorrow morning.
LogicalCC
Chris
Done. I just ordered it. I will DM you.
  • Like
Reactions: CTR
scottjua
Scott
Plano, TX
2025 CW FL5 Type R, 2019 SGP FK8 Type R
Ordered today! Thanks!
  • Like
Reactions: CTR
CTR
CTR
WA
strixauto.com
I sold out of my first batch and recently made a few improvements to this mounting kit. I know a lot of people probably picked up a Project Aero lip during their holiday sale so if you want a better solution this is the kit for you!
Improvements:
Black stainless bolts
Extra stainless washers and Nyloc nuts for Track Mounting (matches PA v2.0 instructions)
Updated the quantity of hardware to match v2.0 design of the lip
scottjua
Scott
Plano, TX
My order just came two days ago… did I get the new an improved?
Robo7
First I’ve heard of a v2.0 of the lip. What did they change?
CTR
CTR
WA
strixauto.com
Thank you for your order! You should have received the previous version which has the increased quantity but not the black bolts. Send me a DM if you really want the new style and we can probably work something out.
Project Aero changed from 4 fasteners to 6 fasteners across the middle. I believe this change was made in October but I don't know the exact time they transitioned.
gotham
Chad
West Virginia
2025 CW Type R
Just installed my lip today with the Strix hardware. A++ to this guy!
install was not bad at all!
thanks for putting together this great kit.
  • Like
Reactions: CTR
scottjua
Scott
Plano, TX
Also wanted to Chime in... I got my Strix kit and it helped immensely. My only issue was on the passenger side... the B bolt wasn't accessible for me because my arm just could NOT fit between the splash guard and the bumper with the windshield washer tank there to get a nylock nut on the bolt. Just impossible for me.
I had to remove a some of the bolts and get that one from under. I made a duct tape fingertip to hold the nut and reach in to get it on the bolt and then it was all good.
Gotta say the kit helped make it manageable... I can't imagine trying it with the stock hardware. No thanks.
11th Gen Honda Civic Project Aero FL5 Front Lip Upgraded Hardware Kit 20260109_105210
gotham
Chad
West Virginia
2025 CW Type R
Also wanted to Chime in... I got my Strix kit and it helped immensely. My only issue was on the passenger side... the B bolt wasn't accessible for me because my arm just could NOT fit between the splash guard and the bumper to get a nylock nut on the bolt. Just impossible for me.
Gotta say the kit helped make it manageable... I can't imagine trying it without the stock hardware. No thanks.
Yeah the passenger B bolt is by far the hardest. Luckily I have pretty skinny arms, and was able to barely get in and under the washer tank and feel around until I found the bolt without dropping anything lol.
coldradio1
Oliver
Nashville, TN
Replaced my bumper today and while I had it off, I decided to swap out the PA hardware for Strix set. NOTABLY nicer hardware and the flat washer design is MUCH better than what PA provides. Highly recommend this product.
11th Gen Honda Civic Project Aero FL5 Front Lip Upgraded Hardware Kit IMG_7131
11th Gen Honda Civic Project Aero FL5 Front Lip Upgraded Hardware Kit IMG_7128
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
After tariffs. How much are people paying for Project Aero lips now a days?
