Any links for Red Honda badges?
drkskeleton
Ian
Hope everyone’s doing well! I was just looking for links or any recommendations for red Honda badges that would fit a 2023 civic si.
pic for attention
thanks all!
11th Gen Honda Civic Any links for Red Honda badges? 8D6EE72F-A10A-4730-BE68-C43AC4A305DA
11th Gen Honda Civic Any links for Red Honda badges? 3E8D8B5D-4F95-408E-9CAE-89CFF68AB9DD
Giovandre
GiO
North Dakota, USA from Puerto Rico (USAF)
youtube.com
2022 Civic Si, 2023 Nissan Pathfinder Platinum
Tickle
Part number 75700-tgh a00
Sidian
James
Miami, FL
2024 FL5
Any updates on this? I ordered off the PRL LINK was recommended but im not sure these are the correct ones for the 11th Gen Si. I tried searching for Part number 75700-TGH A00 but could only find Part number 75700-TGH A01 .
You might double check the sizing. I think the OEM red Honda badges might be too large to fit the space on non-Type R Civics. You may need to look at aftermarket for the right fit.
Sidian
James
Miami, FL
2024 FL5
Seen some Youtube channels with them but cant get a respond yet, Think some are using the RED OEM Back Emblem for both the front and the back but I cant confirm. I just want to avoid aftermarket Emblems since they are not as clean as OEM.
I checked the back of my car and the emblem is indeed smaller than the front emblem. 2 of these smaller emblems are more likely to fit other Civics (front & back). The FL5’s front emblem is quite a bit bigger…like ~25-30% bigger than the back. I didn’t use calipers, but using a ruler, the back emblem is about 3.75”L x 3”H
Sidian
James
Miami, FL
2024 FL5
So I went for it and ordered the Emblems for my Civic Si. I can confirm that part number 75701-TGH-A01 Rear Emblem fits both front and back on the 11th Gen. The fitment on the rear pin holes is a hair length shorter but with a little bit of force will fit snug and flush. The rear stock emblem came off easy but could not save the front stock emblem. Not a big deal as the finish product looks great!
11th Gen Honda Civic Any links for Red Honda badges? 1
11th Gen Honda Civic Any links for Red Honda badges? 2
11th Gen Honda Civic Any links for Red Honda badges? IMG_0950
Read above. The larger emblem only fits the front of the Type R, because the mounting area is smaller on other Civics. You need 2 of the smaller emblems for a perfect fit front and back.
Sidian
James
Miami, FL
2024 FL5
He done goofed.
