Axle or axle boots ?
ChrixFl5
gaspare
pennsylvania
civic type r
What’s up guys. So I messed up a little when installing my springs !and ripped the inner boots on the axles.
Is there anyplace I could order the boots and clips and all that ?
Or whole axle assembly ?
Very stupid noob mistake.
Thanks in advance!
Honda doesnt appear to sell them separately. I doubt you'll find anything listed for FL5's in the aftermarket due to being new, but there are repair boots that likely fit. Get dimensions and search the web.
Not a fun job, but used to be a common fix before cheap axles were widely available.
ChrixFl5
gaspare
pennsylvania
civic type r
Would I be able to order axles from the dealership ?
I'm sure the dealer can get them. FK8's are over $400 each from what I see online.
It looks like there are aftermarket axles for FK8 at Advance Auto Parts for example. Not sure about FL5, but worth checking.
ChrixFl5
gaspare
pennsylvania
civic type r
Often times, people just damage the axle seal when installing springs because they did not loosen/remove the axle nut. This is actually very common. The axle seal is only like $15 from the dealer. I’d start there before replacing a whole axle. I do not have the part number but I’m sure someone here does.
Now that you say that actually my
Driver side axle seal is in fact leaking also. Along with a ripped boot on the passenger side.
TypeR_Kevv
Kevin
Indianapolis
24 CW Type R, 18 Type R (sold), 22 Pilot SE
91205-RT4-003 is the part number for the seal. I was lucky enough to have only damaged the seal and not the axle. It cost me $300 to replace at a reputable shop as I did not want to deal with it at all lol.
Shankmeyster
AZ
23 Type R
Had the same thing happen on my Si when I tried to do a spring swap. Boots can be had separately but they might be on indefinite backorder. I was told they had been backordered for 2 years with no idea when they would be available as a piece so I had to buy an entire axle.
11th Gen Honda Civic Axle or axle boots ? 1727120363519-om
11th Gen Honda Civic Axle or axle boots ? 1727120380347-dk
Dugger
Doug
Bradenton, FL
FL5 Type R
Thank you so much, was searching all over for this part.
I also had a mishap when installing my lowering springs and I'm hoping its just the seal thats ripped. Been slowly leaking fluid on driver side.
TypeR_Kevv
Kevin
Indianapolis
no problem! yea get that seal replaced and you'll be good to go.
