BACK IN STOCK: PRL HVI for 2022+ Civic / Integra 1.5T @ TSP!
Savannah@TSP
www.twostepperformance.com
'23 Si, ‘20 FC4 (sold)
Hey guys!
We just got two massive pallets full of the PRL High Volume Intakes for the 2022+ Civic / Integra 1.5T and have more on the way! As we all know, this intake has been on backorder for a long time and we are super excited to have these back in stock.
11th Gen Honda Civic BACK IN STOCK: PRL HVI for 2022+ Civic / Integra 1.5T @ TSP! 1700078210749
If you don't have one already, you should definitely grab one! PRL makes remarkable products and do not compromise when it comes to quality. This kit utilizes the factory air guide and seal for optimal air flow and heat-soak reduction. The base version of this intake can be run without a tune (standard bore/street).
Want to have a true cold air intake? Grab PRL's High Volume Intake Duct!
11th Gen Honda Civic BACK IN STOCK: PRL HVI for 2022+ Civic / Integra 1.5T @ TSP! 1700064701864
This will require a Resonator Delete Kit (if you don't have the PRL Charge Pipes). To add the duct, you will need to trim a hole at the bottom of the air box, assemble the supplied hardware, and place it at the bottom of the fender well. Unlike the Cobra, this system is better protected from potential hydro locking, and still delivers the great benefits of lower IATs.
11th Gen Honda Civic BACK IN STOCK: PRL HVI for 2022+ Civic / Integra 1.5T @ TSP! 1700078346015
Add some flair to set you apart from the rest with Dress Up Bolts x PRL HVI Titanium Kit! This hardware kit is designed specifically for the 2022+ Civic/Integra 1.5T with 6 different color options!
Be sure to get ahold of these while you can!​
