Bridgestone 265 vs 275
m3bs
South Carolina
2023 CTR, 2016 GT4
I’ve been tracking my car on 18 x 10.5 with 275/35-18 RE71RS. While shopping for RZ replacements, I noticed that the 265 has a “XL” rating with higher load capacity than the larger 275. Same was true for the RS. I’m wondering which would be the better (faster) track tire. Wider tread vs shorter, stiffer sidewall and slightly smaller diameter? Anybody tried both sizes?
scuderia_miso
Teddy
Pacific Northwest
FL5, AP2
Since you have the 10.5" wide wheel the 275 should give you plenty of sidewall stiffness. The RZ and RS are not lacking in the sidewall stiffness department, IMO.
If it were me, I would run the 275 since it will give you an extra 0.2 lbs of thermal mass, which these tires need since they start to fall off when heated/overheated.
That being said, if you really like tight steering response or if you were a novice, I would not be surprised if the 265 was faster for you.
The gearing difference is small but could matter depending on the track(s) you run at. For example, if you have corners were you bounce off the limiter right before a braking zone instead of upshifting, a couple mph could be noticeable. Third gear is +1.4 mph with the 275 and 4th would be around +1.9 so that's not nothing.
These cars have pretty good torque so I dont think the shorter gearing is really going to help you in that regard.
